Find all integers, such that ....
  • MHB
  • Thread starter lfdahl
  • Tags
    Integers
In summary, kaliprasad and Albert discussed finding all integers, $n$, such that the set $\{1,2,3,4, ...,n\}$ can be written as the disjoint union of subsets $A$, $B$, and $C$, whose sums of elements are equal. They also suggested a method for constructing sets $A$, $B$, and $C$ for some cases but not all. The suggested solution uses a short and clear argument for finding the common values of $n$.
lfdahl
MHB
749
Find all integers, $n$, such that the set $\{1,2,3,4, ...,n\}$ can be written as the disjoint union of the subsets, $A$, $B$ and $C$ -whose sums of elements are equal.
Mathematics news on Phys.org
$S_n=\dfrac {n(n+1)}{2}$ must be a multiple of 3, and $n>4$
if :$n=5,$$S_5=15$ and $\dfrac {15}{3}=5=$ sums of elements
we may set :A={$1,4$},B={$2,3$}, C={$5$} and all its combinations
if :$n=6,$$S_6=21$ and $\dfrac {21}{3}=7=$ sums of elements
we may set :A={$1,6$},B={$3,4$}, C={$2,5$} and all its combinations
from above we get :
case 1: $n=5,8,11,14,---=3p+2 ,p\geq 1$
case 2: $n=6,9,12,15,---=3q+3 ,q\geq 1$
we may set :{$A=1,4$},{$B=2,3$}, {$C=5$} and all its combinations
we may set :{$A=1,6$},{$B=3,4$}, {$C=2,5$} and all its combinations
from above we get :
Good job, Albert!:cool:Thankyou for your solution!
Solution provided by Albert is good but can we make the sets A, B, C for the above n. he has provided for some cases but not all.
I here mention how to build A,B,C. this is one method and takes care of solution and not all solutions
Now for the common part
Any six consecutive number say 6p to 6p+5 we can choose $ A = \{6p, 6p+5\} , B = \{6p + 1, 6p+4\} ,C = \{6p+2, 6p+3\}$
1st 9 numbers we can choose $A = \{4,9,2\},B = \{3,5,7\}, C =\{(1,6,8\}$
using above
for the case of n = n is of the form 3p + 2 where p >= 1
p =1 or n= 5 gives $\{4,1\},\{2,3\}, \{5\}$ ( Albert has mentioned)
p =2 or n= 8 gives $\{4,8\},\{1,5,6\}, \{(2,3,7\}$
for p >2 we if p odd we have n = 5 + 6k
we get the groups above( n = 5) and from groups of 6 as mentioned above
if p even we have n = 8 + 6k
we get the groups above( n = 8) and from groups of 6 as mentioned above
for n of the form 3p:
p is even: we can choose the elements from groups of 6 then combine for example to choose from (1..12) choose ((1,6),(2,5),(3,4)) from (1.. 6) and (7,12), (8,11),(9, 10) from (7..12) and combine to get (1,6,7,12),(2,5,8,11),(3,4,9,10)
p is odd: choose from 1st 9 elements and elements from groups of 6 and combine to get the result
Hi, kaliprasad and Albert. Thankyou for your participation and clever solutions!
Your discussion on the possible values of $n$ is interesting, and the suggested solution below uses a surprisingly short and clear argument:
To find the possible $n$-values, observe that:$\sum_{x \in A}+\sum_{x \in B}+\sum_{x \in C} = \frac{1}{2}n(n+1)$, which is divisible by $3$.It follows, that $n$ must be congruent to $0,2,3$ or $5$ modulo $6$. Therefore $n \le 4$ can be excluded.So the list of $n$-values begins with: $n \in \left\{5,6,8,9,11, ...\right\}$For $n = 5,6,8,9$ we have the following partitions:\[ n = 5:\: \: \: \: A = \left \{ 1,4 \right \}\: \: \: B = \left \{ 2,3 \right \}\: \: \: C = \left \{ 5 \right \} \\\\ n = 6:\: \: \: \: A = \left \{ 1,6 \right \}\: \: \: B = \left \{2,5 \right \}\: \: \: C = \left \{3,4 \right \} \\\\ n = 8:\: \: \: \: A = \left \{1,2,3,6 \right \}\: \: \: B = \left \{ 5,7 \right \}\: \: \: C = \left \{ 4,8 \right \} \\\\ n = 9:\: \: \: \: A = \left \{ 1,2,3,4,5 \right \}\: \: \: B = \left \{7,8 \right \}\: \: \: C = \left \{ 6,9 \right \} \\\\ \]Now, to proceed with a $n+6$-value (e.g. $11$), we can use the nice procedure, which kaliprasad suggested:Use the partition depicted for $n=5$: Now join $n+1$ and $n+6$ to $A$, $n+2$ and $n+5$ to $B$ - and $n+3$ and $n+4$ to $C$.
this is a question of combination
in fact $A,B,\,\,and\,\, C$ are interchangeable
for $n=5,8,11,14, ----=3p+2, p\in N, P\geq 1 $ in one group
and $n=6,9,12,15----=3q+3 ,q\in N, q\geq 1 $ as another category
for each type of n,using method of combinatin to find all possible combinatons of $A,B,$and $C$
as mention above
in this question $A,B,$ and $C$ are not main characters, for we are asked to find all possible values of n
take $n = 8:\: \: \: \: A = \left \{4,8 \right \}\: \: \: B = \left \{ 1,5,6 \right \}\: \: \: C = \left \{ 2,3,7\right \}$
also we may set $A = \left \{5,7 \right \}\: \: \: B = \left \{ 4,8 \right \}\: \: \: C = \left \{ 1,2,3,6\right \}$
so the sets of $A,B,C$ are not unique
FAQ: Find all integers, such that ....
What does "integers" mean in this context?
Integers are whole numbers, both positive and negative, and zero. They do not include fractions or decimals.
How do I find all the integers that satisfy the given condition?
To find all the integers that satisfy a given condition, you can use mathematical techniques such as algebra or number theory. Alternatively, you can use a computer program or calculator to generate a list of integers that fit the criteria.
Are there any restrictions on the values of the integers?
The restrictions on the values of the integers will depend on the specific problem or condition given. Some problems may have a limited range of values, while others may allow for any integer to be a solution.
How do I know if I have found all the possible solutions?
To ensure that you have found all the possible solutions, you can check your work by plugging the integers back into the original equation or condition. You can also use mathematical proofs or algorithms to verify that you have found all the possible solutions.
Can you give an example of a problem involving finding all integers?
One example of a problem involving finding all integers is "Find all integers x such that 2x + 1 = 11." The solutions to this problem are x = 5 and x = 10, as plugging these values into the equation results in 11 on both sides.
