Find all pairs of primes ## p ## and ## q ## satisfying ## p-q=3 ##.
  • Thread starter Thread starter Math100
    Primes
The only pair of primes satisfying the equation p - q = 3 is (5, 2). The proof begins by considering two cases: if p is even, it must be 2, leading to a contradiction since q would be -1. In the second case, if p is an odd prime, it can be expressed as 2k + 1, resulting in q being even. Since the only even prime is 2, the only valid solution is when q equals 2 and p equals 5. Thus, the conclusion is that the only primes differing by 3 are 5 and 2.
Math100
None.
Proof:
Let ## p ## and ## q ## be primes such that ## p-q=3 ##.
Now we consider two cases.
Case #1: Suppose ## p ## is an even prime.
Then ## p=2 ##, because ## 2 ## is the only even prime.
Thus ## 2-q=3 ##, so ## q=-1 ##,
which contradicts the fact that ## q ## is prime.
Case #2: Suppose ## p ## is an odd prime.
Then ## p=2k+1 ## for some ## k\in\mathbb{N} ##.
Thus ## 2k+1=q+3 ##
## q=2k+1-3 ##
## =2k-2 ##
## =2(k-1) ##.
This means ## q ## is an even prime.
Now we have ## p-2=3 ##, so ## p=5 ##.
Therefore, the pair of primes ## p ## and ## q ## satisfying ## p-q=3 ## is ## (p, q)=(5, 2) ##.
Math100 said:
Homework Statement:: Find all pairs of primes ## p ## and ## q ## satisfying ## p-q=3 ##.
Relevant Equations:: None.
Proof:
This is much more general than it needs to be. The only even prime is 2, so the only primes that satisfy this case are q = 2 and p = 5.
Better:
## p-q=3 \Rightarrow p = q + 3##
By inspection it can be seen that q = 2 and p = 5 are two primes that satisfy the given equation.
Now suppose that q is prime with q > 2.
Necessarily q is odd, with q = 2n + 1 for some integer n.
Then p = q + 3 = 2n + 1 + 3 = 2n + 4 = 2(n + 2), which is an even integer, this not a prime.
##\Rightarrow \Leftarrow## Note that a pair of arrows that butt heads are often used to indicate a contradiction.
Therefore, the only primes that differ by 3 are 2 and 5.
Thus ## 2k+1=q+3 ##
## q=2k+1-3 ##
## =2k-2 ##
## =2(k-1) ##.
Likes pbuk and Math100
If ## p - q = 3 ## then ## p ## and ## q ## have opposite parity.
The only even prime is ## 2 ## so either ## p = 2 ## or ## q = 2 ##.
## p = 2 \implies q = -1 ## which is not a solution.
## q = 2 \implies p = 5 ## which is therefore the only solution.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
