Find all points with same distance to (A) and (B)
  • Thread starter reedy
  • Tags
    Points
In summary, to find all points (x1,x2,x3) that have the same distance to A and B, we can first find the line they both lie on using the equation L=(3,4,-3)+t(2,1,-3). Then, we can find the plane with point C=(A+B)/2 and normal L, which can be found by brute force or by using analytic geometry. Alternatively, we can pull out the normal from L's equation and use the mid-point formula (A+B)/2 to find the equation of the plane.
reedy
37
I have two given points.
A=(-1,2,3) and B=(3,4,-3).
I want to find all points (x1,x2,x3) that have the same distance to A and B.
Attempt:
I think finding the line they both lie on is a good first step. To do this, I've drawn a vector between A and B, and found the line's equation. L=(3,4,-3)+t(2,1,-3). I've come to the conclusion that I have to find a perpendicular bisector of some sort. And I guess cross product won't work, cause I only have one line(?). What is the next step?
A perpendicular bisector would be appropriate in two dimensions, but in three dimensions we are looking for a plane with normal L.
We can find it by bruteforce:
[itex](x,y,z)[/itex] is
[tex]\sqrt{(x+1)^2+(y-2)^2+(z-3)^2}[/tex]
from A and
[tex]\sqrt{(x-3)^2+(y-4)^2+(z+3)^2}[/tex]
from B so you're looking for all triples (x,y,z) such that:
[tex]\sqrt{(x+1)^2+(y-2)^2+(z-3)^2} = \sqrt{(x-3)^2+(y-4)^2+(z+3)^2}[/tex]
Square, expand and cancel a bit and you should get the equation of a plane that describes all points equally far from A and B.
You could also have noted that [itex]C=(A+B)/2[/itex] is equally far from A and B, so you want to find the plane with point C and normal CA. From analytic geometry you should be able to find this plane (the same as before), but in my opinion this is more complicated than bruteforce.
Of course! What was I thinking...
But if that is true, which it is, wouldn't it be easier to just use the fact that
[PLAIN said:
http://en.wikipedia.org/wiki/Normal_vector]For[/PLAIN] a plane given by the equation ax + by + cz = d, the vector (a,b,c) is a normal.
and pull out the normal from L's equation, (2,1,-3), and establish that the plane's equation is 2x1+x2-3x3?
If so, I would need a right hand side as well. And the only point I know for sure in the plane is C.
You say that C=(A+B)/2. Why is that? Is it plain ol' division on each coordinate? (-1,2,3)+(3,4,-3)=(2,6,0) // division // (1,3,0)
Gives me: 2x1+x2-3x3=5 which is a correct answer according to the textbook. But the last step confused me.
Yes it would be possible, and what you find easiest is up to you. Neither is particularly complicated.
Yes. We use (A+B)/2 because that is the mid-point of the line segment connecting A and B. For one way of seeing this consider the vector AB. Adding half of this to A we get half-way to B from A so:
C = A + 1/2 * AB = A + 1/2(B-A) = 1/2(A+B)
Ahh, perfect. Now I see it - thanks a bunch!
FAQ: Find all points with same distance to (A) and (B)
1. How do I calculate the distance between two points?
To calculate the distance between two points, you can use the distance formula, which is √((x2-x1)^2 + (y2-y1)^2). The x and y values represent the coordinates of each point.
2. What does it mean for two points to have the same distance to point A and B?
If two points have the same distance to point A and B, it means that they are equidistant from both points. This can also be referred to as being equidistant from a line segment.
3. Can there be more than one point that has the same distance to points A and B?
Yes, it is possible for there to be more than one point with the same distance to points A and B. In fact, there can be an infinite number of points that satisfy this condition.
4. How can I find all the points with the same distance to points A and B on a graph?
To find all the points with the same distance to points A and B on a graph, you can plot the two points A and B, and then draw a circle with its center at the midpoint between A and B. The radius of the circle will be the distance between A and B. Any point on the circumference of the circle will have the same distance to points A and B.
5. Is there a specific method for finding all the points with the same distance to points A and B?
Yes, there is a specific method for finding all the points with the same distance to points A and B. It involves using the distance formula and setting the distance equal to the radius of a circle centered at the midpoint between A and B. This will give you the equation of the circle, and any point on the circumference of this circle will have the same distance to points A and B.
