Find all quadruples (r, s, t, u)
  • MHB
  • Thread starter anemone
In summary, the purpose of finding all quadruples (r, s, t, u) is to identify all possible combinations of four elements that satisfy a given condition or equation. The variables (r, s, t, u) represent four different elements or numbers that can be combined to form a quadruple. To find all quadruples, systematic generation and checking of all possible combinations is required. Some real-life applications of this include cryptography, coding theory, and combinatorics. However, there are limitations to this approach depending on the size and complexity of the elements involved.
anemone
MHB
POTW Director
3,883
115
Find all quadruples $(r,\,s,\,t,\,u)$ of positive real numbers such that $rstu=1$, $r^{2012}+2012s=2012t+u^{2012}$ and $2012r+s^{2012}=t^{2012}+2012u$.
Mathematics news on Phys.org
anemone said:
Find all quadruples $(r,\,s,\,t,\,u)$ of positive real numbers such that $rstu=1---(1)$,
$r^{2012}+2012s=2012t+u^{2012}---(2)$ and
$2012r+s^{2012}=t^{2012}+2012u---(3)$.
by observation ,we may let:
$r=u=\dfrac {1}{s},$ and $s=t$
Hi Albert,
Thanks for your reply...perhaps you want to prove that there are no other solutions other than the one you cited by using the AM-GM inequality formula?:eek:
Solution of other:
Rewrite the last two equations as
$r^{2012}-u^{2012}=2012(t-s)$---(1)
$t^{2012}-s^{2012}=2012(r-u)$---(2)
Next, observe that $r=u$ holds iff $t=s$ holds. In that case, the last two equations are satisfied and the condition $rstu=1$ leads to a set of valid quadruples of the form $(r,\,s,\,t,\,u)=(k,\,\dfrac{1}{k},\,\dfrac{1}{k},\,k)$ for any $k>0$.
We now show that there are no other solutions. Assume that $r\ne u$ and $t\ne s$. Multiply the equation (1) by (2) we have
$(r^{2012}-u^{2012})(t^{2012}-s^{2012})=2012^2(t-s)(r-u)$
and divide the LHS by the RHS to get
$\dfrac{r^{2011}+\cdots+r^{2011-i}u^i+\cdots+u^{2011}}{2012}\cdot \dfrac{t^{2011}+\cdots+t^{2011-i}s^i+\cdots+s^{2011}}{2012}=1$
Now, applying the AM-GM inequality to the first factor, we have
$\dfrac{r^{2011}+\cdots+r^{2011-i}u^i+\cdots+u^{2011}}{2012}>\sqrt[2012]{(ru)^{\small\dfrac{2011\times 2012}{2}}}=(ru)^{\small{\dfrac{2011}{2}}}$
The inequality is strict, since equality holds only if all terms in the mean are equal to each other, which happpens only if $r=u$.
Similarly, we find
$\dfrac{t^{2011}+\cdots+t^{2011-i}s^i+\cdots+s^{2011}}{2012}>\sqrt[2012]{(ts)^{\small\dfrac{2011\times 2012}{2}}}=(ts)^{\small{\dfrac{2011}{2}}}$
Multiply both inequalities we obtain $(ru)^{\small{\dfrac{2011}{2}}}(ts)^{\small{\dfrac{2011}{2}}}<1$ which is equivalent to $rstu<1$, a contradiction.
I would first recognize that this problem involves finding a set of four positive real numbers that satisfy three equations. This is a system of equations, and solving systems of equations is a common problem in mathematics and science. To find all possible solutions, I would approach this problem by first isolating one variable in each equation and substituting it into the other equations.
Starting with the first equation, $rstu=1$, we can isolate one variable by dividing both sides by the other three variables. This gives us $r=\frac{1}{stu}$. We can then substitute this value for $r$ into the other two equations to get:
$\frac{1}{stu^{2012}}+2012s=2012t+u^{2012}$ and $2012\left(\frac{1}{stu}\right)+s^{2012}=t^{2012}+2012u$
Next, we can rearrange these equations to get all the variables on one side and a constant on the other side:
$2012t-u^{2012}=\frac{1}{stu^{2012}}-2012s$ and $2012u-t^{2012}=s^{2012}-2012\left(\frac{1}{stu}\right)$
Now, we can use the substitution method to solve this system of equations. We can substitute the first equation into the second equation to get:
$2012u-\left(\frac{1}{stu^{2012}}-2012s\right)^{2012}=s^{2012}-2012\left(\frac{1}{stu}\right)$
This gives us a single equation with only three variables: $u$, $s$, and $t$. We can then use algebraic manipulation to solve for one of these variables in terms of the other two. For example, we can solve for $u$ by isolating it on one side of the equation:
$2012u=s^{2012}-2012\left(\frac{1}{stu}\right)+\left(\frac{1}{stu^{2012}}-2012s\right)^{2012}$
$u=\frac{s^{2012}+2012s-2012\left(\frac{1}{stu}\right)+\left(\frac{1}{stu^{2012}}\right)^{2012}}{2012}$
We
FAQ: Find all quadruples (r, s, t, u)
What is the purpose of finding all quadruples (r, s, t, u)?
The purpose of finding all quadruples (r, s, t, u) is to identify all possible combinations of four elements (r, s, t, u) that satisfy a given condition or equation.
What do the variables (r, s, t, u) represent in finding all quadruples?
The variables (r, s, t, u) represent four different elements or numbers that can be combined to form a quadruple. These elements can be integers, fractions, or any other mathematical entities.
How do you find all quadruples (r, s, t, u)?
To find all quadruples (r, s, t, u), you need to systematically generate all possible combinations of the four elements and then check if they satisfy the given condition or equation. This can be done using mathematical techniques such as permutation and combination.
What are some real-life applications of finding all quadruples (r, s, t, u)?
Finding all quadruples (r, s, t, u) has various applications in fields such as cryptography, coding theory, and combinatorics. It can also be used in solving mathematical problems and puzzles.
Are there any limitations to finding all quadruples (r, s, t, u)?
Yes, there are limitations to finding all quadruples (r, s, t, u) depending on the size and complexity of the elements involved. For larger or more complex elements, it may not be feasible to generate and check all possible combinations, and alternative methods may need to be used.
