MHB Find All Real Solutions: Is x = 0 a solution to the equation?
  • Thread starter Thread starter mathdad
The discussion confirms that x = 0 is indeed a solution to the equation x = rt{3x + x^2 - 3•rt{3x + x^2}}. The calculations show that substituting x = 0 into the equation simplifies correctly to 0 = 0, validating the solution. The method used to derive this solution is also affirmed as correct. Participants emphasize the importance of verifying solutions to ensure they satisfy the original equation. The conclusion is that x = 0 is a valid real solution.
mathdad
Find all the real solutions of the equation.
Let rt = root
(x)^2 = [rt{3x + x^2 - 3•rt{3x + x^2}}]^2
x^2 = 3x + x^2 - 3•rt{3x + x^2}
x^2 - x^2 - 3x = - 3•rt{3x + x^2}
-3x = -3•rt{3x + x^2}
-3x/-3 = rt{3x + x^2}
x = rt{3x + x^2}
(x)^2 = [rt{3x + x^2}]^2
x^2 = 3x + x^2
x^2 - x^2 = 3x
0 = 3x
0/3 = x
0 = x
Correct?
Mathematics news on Phys.org
Let rt = root
x = rt{3x + x^2}
x^2 = 3x + x^2
x^2 - x^2 = 3x
0 = 3x
0/3 = x
0 = x
Correct?
Your method is correct. You must also check that the answer you have found actually works to make the equation true.
Check:
Let x = 00 = rt{3(0) + (0)^2 - 3•rt{3(0) + (0)^2}}
0 = rt{0 + 0 - 3rt{0 + 0}}
0 = rt{0 + 0 - 3rt{0}}
0 = rt{0 + 0 - 0}
0 = rt{0}
0 = 0
It checks to be true.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
