Find all real solutions of a, b and c
  • MHB
  • Thread starter anemone
In summary, there is only one real solution for the system of equations provided. It is the "obvious" solution of $a=b=c=2$. Any other solution with $a>2$ or $a<2$ would lead to contradictions, proving that there are no other real solutions. This solution was provided by Opalg and is greatly appreciated.
anemone
MHB
POTW Director
3,883
115
Find all real solutions $a,\,b,\,c$ of the system of equations below:
$a^3+b=3a+4$
$2b^3+c=6b+6$
$3c^3+a=9c+8$
Mathematics news on Phys.org
$a^3+b=3a+4$
$2b^3+c=6b+6$
$3c^3+a=9c+8$
[sp]The "obvious" solution is $a=b=c=2$. In fact, if $a=2$ then the first equation says that $b=2$. The second equation then says that $c=2$, and the third equation confirms that $a=2$.
Now suppose that there is another solution with $a>2$. Then the first equation says that $b<2$. The second equation then says that $c>2$, and the third equation says that $a<2$. But that contradicts the assumption that $a>2$, so there are no such solutions.
Similarly, if there is a solution with $a<2$ then the first equation says that $b>2$. The second equation then says that $c<2$, and the third equation says that $a>2$. Again, that contradicts the assumption that $a<2$, so there are no such solutions.
Therefore there is only the one solution.[/sp]
This is definitely an eye-opening solution for me...thank you so much Opalg for your great solution and thanks for participating!
Algebraic solution of other:
From $a^3+b=3a+4$, rewrite it so we have $a^3-1-1-3a=2-b\,\implies\,(a-2)(a-1)^2=2-b$---(1)
From $2b^3-2-2-6b=2-c$, rewrite it such that $2(b-2)(b+1)^2=(2-c)$---(2) and
$3c^3-3-3-9c=2-a$ gives $3(c-2)(c+1)^2=(2-a)$---(3)
Multiplying all three equations (1), (2) and (3) yields
$(a-2)(b-2)(c-2)(6(a-1)^2(b+1)^2(c+1)^2+1)=0$
As the last factor is always positive for all real $a,\,b,\,c$, we must have $(a-2)(b-2)(c-2)=0$.
In conjunction with (1), (2), (3), this gives the unique solution $a=b=c=2$.
FAQ: Find all real solutions of a, b and c
What does it mean to find all real solutions of a, b, and c?
Finding all real solutions of a, b, and c means finding all possible values for the variables a, b, and c that satisfy the given equation or problem. These values must be real numbers, meaning they can be found on the number line and do not include imaginary numbers.
Why is it important to find all real solutions of a, b, and c?
It is important to find all real solutions of a, b, and c because it allows us to fully understand and solve a given problem or equation. By finding all possible solutions, we can be confident that we have not missed any important values or information.
How do you find all real solutions of a, b, and c?
To find all real solutions of a, b, and c, we first need to set up the equation or problem and then use mathematical techniques such as factoring, substitution, or the quadratic formula to solve for the variables. We then check our solutions by plugging them back into the original equation to ensure they are valid.
What if there are no real solutions for a, b, and c?
If there are no real solutions for a, b, and c, it means that the given equation or problem has no solution. This could be due to a variety of reasons, such as a mistake in the problem or a limitation of the mathematical techniques used to solve it. In this case, it is important to reevaluate the problem and potentially seek help from a teacher or tutor.
Can there be more than one set of real solutions for a, b, and c?
Yes, there can be more than one set of real solutions for a, b, and c. This is because some equations or problems may have multiple valid solutions that satisfy the given conditions. It is important to check all solutions and select the appropriate ones based on the context of the problem.
