Find all solutions in integers of (a, b)
  • MHB
  • Thread starter anemone
  • Tags
    Integers
In summary, the equation $a^3+(a+1)^3+(a+2)^3+\cdots+(a+7)^3=b^3$ has four solutions in integers, with two of them being $a = -1, b = 0$ and $a = 1, b = 2$. The other two solutions have not been identified.
anemone
MHB
POTW Director
3,883
115
Find all solutions in integers of the equation $a^3+(a+1)^3+(a+2)^3+\cdots+(a+7)^3=b^3$
Mathematics news on Phys.org
Hello.
A little bit. to brute force. :eek::eek:
My experience with cubic powers:
[tex]3^3+4^3+5^3=6^3[/tex]
It no more, correlative of 4 elements.
You need 5 correlative elements, which are cancelled:
[tex](-2)^3+(-1)^3+0^3+1^3+2^3=0[/tex]
Solution:
1º) [tex](-6)^3=(-5)^3+(-4)^3+ \cdots+1^3+2^3[/tex]
[tex]a=-5 \ and \ b=-6[/tex]
2º) [tex]6^3=5^3+4^3+ \dots +(-1)^3+(-2)^3[/tex]
[tex]a=-2 \ and \ b=6[/tex]
Regards.
mente oscura said:
Hello.
Solution:
Regards.
Hi mente oscura, the two set solutions are correct, but there are a total of 4 answers, could you please also identify the other two?:eek:
$(-4,-4)$: $-64 -27 -8 -1 +0 +1 +8 + 27 = -64 = (-4)^3$
$(-3,4)$: $-27-8-1+0+1+8+27+64=4^3$.
Edit: Oops, made a typo: $8 = 2^3 \neq 4$.
$$a^3 + \cdots + (a+7)^3 = 8a^3 + 84a^2 + 420a + 784$$
So the cubic curve of interest is $8a^3 + 84a^2 + 420a + 784 = b^3$ over $\Bbb Q$. This obviously have a rational point, take for example $(a, b) = (-4, -4)$. Thus it's isomorphic to an elliptic curve.
In particular, use the parametrization
$$(x, y) = \left (\frac{1008b}{2a+7}, \frac{254016}{2a + 7} \right )$$
To reduce the above into the well-known Mordell form
$$\mathbf {E} : y^2 = x^3 -1024192512$$
I do hope this has rank $1$, though. (I believe BSD)
First, the trivial solutions over $\Bbb Q$ include $(-7/2, 0), (-4, -4), (-3, 4)$, the first being simply a real zero of the cubic. Now about computing the torsion, one can try a relatively easy hands-on derivation by either Nagell-Lutz or Mazur (I am not sure which one is easier here). Precisely, it's $\Bbb Z/2\Bbb Z$ so the group of rational points over the elliptic curve is really $\Bbb Z \times \Bbb Z/ 2\Bbb Z$.
The extra solutions may come from the torsion points. It seems that a generator for $\mathbf E$ is $(2016, 84672)$ and from this comes the corresponding integral point $(-2, 6)$.
I am missing something here.
EDIT : Darn, I forgot the negative $(2016, -84672)$. Of course, plugging this in gives $a = -5$ and $b = 6$, and thus all the integer points (and as well rational points, which are the multiplies of the generator precisely).
Hello.
You're right, I am missing identities:
[tex](-3)^3+(-2)^3+(-1)^3+0+1^3+2^3+3^3=0[/tex]
Therefore:
3º) [tex]a=4 \ and \ b=4[/tex]
4º) [tex]a=-4 \ and \ b=-4[/tex]
Regards.
Thank you all for participating!:)
Solution I saw somewhere online:
Let $f(a)=a^3+(a+1)^3+(a+2)^3+(a+3)^3+(a+4)^3+(a+5)^3+(a+6)^3+(a+7)^3=8a^3+84a^2+420a+784$Case I:
If $a>0$:
Note that $(2a+7)^3=8a^3+84a^2+294a+343$ and $(2a+10)^3=8a^3+120a^2+600a+1000$
So if $a>0$, we have
$(2a+7)^3<f(a)<(2a+10)^3$, i.e. $2a+7<b<2a+10$ which implies $b=2a+8$ or $b=2a+9$.
And neither of the equations $f(a)-(2a+8)^3=-12a^2+36a+272=0$ and $ f(a)-(2a+9)^3=-24a^2-66a+55=0$ have any integer roots, so we can conclude that there are no solutions with $x>0$.
Case II:
Note that $f$ satisfies $f(-a-7)=-f(a)$, so $(a,\,b)$ is a solution iff $(-a-7,\,-b)$. Therefore, there are no solutions with $a<-7$.
So for $(a,\,b)$ to be a solution, we must have $-6<a<-1$.
Checking each case we have
$f(-1)=440$ and this isn't a cube.
$f(-2)=216=6^3$
$f(-3)=64=4^3$
Therefore, $(-2,\,6)$ and $(-3,\,4)$ are the only solutions with $-3<a<-1$ and $(-4,\,-4)$ and $(-5,\,-6)$ are the only solutions with $-6<a<-4$.
Darn it. I never think straight. :D
FAQ: Find all solutions in integers of (a, b)
What does it mean to find all solutions in integers?
Finding all solutions in integers means finding all possible combinations of two numbers (a and b) that satisfy a given equation or problem, where the numbers are whole numbers (positive, negative, or zero).
How do you find all solutions in integers?
To find all solutions in integers, you need to first understand the given equation or problem and then use mathematical techniques such as algebra, number properties, and logic to manipulate and solve the equation. By systematically trying different values for a and b, you can find all possible solutions that satisfy the given equation.
Why is it important to find all solutions in integers?
Finding all solutions in integers is important because it helps us understand the full range of possible solutions to a given problem. It also allows us to check if our solution is the only one or if there are multiple solutions. In some cases, finding all solutions in integers can also help us identify patterns and generalize solutions for similar problems.
Can there be an infinite number of solutions when finding all solutions in integers?
Yes, there can be an infinite number of solutions when finding all solutions in integers. For example, if we are finding all solutions for the equation x + y = 10, there are infinite combinations of two integers that add up to 10 (e.g. 1 + 9, 2 + 8, 3 + 7, etc.). However, in some cases, there may be a finite number of solutions or even no solutions at all.
How can finding all solutions in integers help in real-life situations?
Finding all solutions in integers can help in real-life situations by providing a systematic approach to problem-solving. It allows us to explore all possible options and find the best solution. In fields such as computer science and engineering, finding all solutions in integers is important for optimizing systems and algorithms. It can also help in practical situations such as budgeting and scheduling where whole numbers are used.
