Find all solutions of u_(xx) + u_(yy) = 0, form u(x,y) = f(x^2 + y^2)
  • Thread starter Thread starter coverband
    Form
coverband
170
1. Find all solutions of u_(xx) + u_(yy) = 0 which have the form u(x,y) = f(x^2 + y^2).
3. General solution of laplace is u(x,y)= Eexp(ky)Coskx + Fexp(-ky)Coskx + Gexp(ky)Sinkx + Hexp(-ky)Sinkx, where E,F,G,H are arbitrary constants don't see how this can be linked to f(x^2+y^2)?
I suppose the idea is, that you can write u_{xx} = \partial^2 u/\partial x^2 and u_{yy} = \partial^2 u/\partial y^2 in terms of the "total" derivative df(r)/dr, making it an ordinary differential equation for f.
Why no attempt at all? Suppose u(x,y)= f(x^2+ y^2). What are u_xx and u_yy in terms of f? If you let z= x^2+ y^2, that reduces to a fairly simple d.e. for f(z).
No, that is NOT the general solution to Laplace's equation. You could also have an infinite sum of such things- i.e. any function that has a Fourier series could be a solution.
Hi Halls
Yes I was thinking of doing that initially.
u_xx=2f'(x^2+y^2)+4(x^2)f''(x^2+y^2)
u_yy=2f'(x^2+y^2)+4(y^2)f''(x^2+y^2)
Are you saying the addition of these is the answer!?
What is the new diff.equation you get?
Hint: write it in terms of z = x^2 + y^2 as Halls suggested.
The answer is what you get when you solve this equation.
PS Final hint for solving: consider the derivative of z f'(z)
coverband said:
Hi Halls
Well, no, adding those is not "the answer"- but gives, as I said, a simple equation to solve to get the answer.
Adding those gives u_{xx}+ u_{yy}= 4f '(x^2+ y^2)+ 4(x^2+ y^2)f"(x^2+ y^2)= 0. Setting z= x^2+ y^2, as I suggested, gives the ordinary differential equation 4f '(z)+ 4z^2f"(z)= 0. Letting g(z)= f'(z) reduces that to a simple first order equation for g. After finding g, integrate to get f.
Except that it is <br /> 4f&#039;(z)+ 4zf&quot;(z)= 0<br />, not <br /> 4f&#039;(z)+ 4z^2f&quot;(z)= 0<br />
You are right. I guess my mind shifted to "r= \sqrt{x^2+ y^2}" while I was writing!
Thanks guys
The answer appears to be f(x^2+y^2)=Aexp(-(x^2+y^2)) where A is an arbitrary constant
Thanks for your help
