Find an equation of a line of symmetry in the form px+qy = r
In summary, the conversation discusses finding an equation of the line of symmetry for an isosceles triangle given its coordinates and the equation of a line that it lies on. The solution involves finding a perpendicular line passing through the given point and then converting it into the form px + qy = r with integers. The final answer can be expressed in multiple equivalent forms, such as (3/2)x + y = 43 or 3x + 2y = 86.
Natasha1
493
ABC is an isosceles triangle such that
AB = AC
A has coordinates (4, 37)
B and C lie on the line with equation 3y = 2x + 12
Find an equation of the line of symmetry of triangle ABC.
Give your answer in the form px + qy = r where p, q and r are integers. Show clear algebraic working.
Would the equation of the line of symmetry of triangle ABC be y = -3/2 x + c (as it's perpendicular to y=2/3x + 4)
So as it goes through A (4,37) we get y = -3/2 x + 43
How on Earth do you get the form px + qy = r
AB = AC
Doesn't the equivalent form ##(3/2) x + 1 y = 43## count? What about ##3 x + 2 y = 86?##
Likes Natasha1 and Phylosopher
Ray, you are a star! Thanks so much :)
Related to Find an equation of a line of symmetry in the form px+qy = r
1. What is a line of symmetry?
A line of symmetry is a line that divides a figure into two equal parts, such that if one part is folded over the line, it will perfectly overlap with the other part. In other words, the two parts are mirror images of each other.
2. How do you find the equation of a line of symmetry?
To find the equation of a line of symmetry, you need to know the coordinates of at least two points on the line. Once you have the coordinates, you can use the midpoint formula to find the midpoint of the line. The equation of the line of symmetry will be in the form px+qy=r, where p and q represent the slope of the line and r represents the y-intercept.
3. What is the significance of the equation px+qy=r for a line of symmetry?
The equation px+qy=r represents the line of symmetry because it satisfies the condition that any point on the line is equidistant from the two halves of the figure. This means that the line of symmetry will have the same slope and y-intercept as the original figure, making it a mirror image of the figure.
4. Can you have more than one line of symmetry for a figure?
Yes, it is possible to have more than one line of symmetry for a figure. For example, a square has four lines of symmetry, while a regular hexagon has six lines of symmetry. However, some figures may not have any lines of symmetry at all.
5. How do you use the equation of a line of symmetry to reflect a figure?
To use the equation of a line of symmetry to reflect a figure, you can plug in the coordinates of any point on the original figure into the equation. The resulting point will be the reflection of the original point across the line of symmetry. This process can be repeated for all points on the figure to create a mirrored image.
