Find an equation of the line that is perpendicular to x - y + 2 = 0
  • MHB
  • Thread starter mathdad
In summary, the equation of the line that is perpendicular to x - y + 2 = 0 and passes through the point (3,1) can be written as y = -x + 4 or in standard form as x + y - 4 = 0.
mathdad
1,283
Find an equation of the line that is perpendicular to x - y + 2 = 0 and passes through the point (3,1). Write your answer in two forms: y = mx + b and Ax + By + C = 0.
The equation we want is perpendicular to the given equation. This means the slope must be the negative reciprocal of the slope of the given equation.
True?
Steps:
1. Solve the given equation for y.
2. Find the negative reciprocal slope of the equation in step 1.
3. Plug the slope from step 2 and the point (3,1) into the point-slope formula and solve for y.
4. Express the equation in the form Ax + By + C = 0
Correct?
Mathematics news on Phys.org
For step 3, don't you mean "solve for b" instead of "solve for y"? (Wondering)
Other than that detail, I am in agreement with what you have posted. :)
Why solve for b in step 3? The slope m is required for the needed equation not the y-intercept or b.
Sorry; I mistook "point-slope" for "slope-intercept". At any rate, I don't see why you'd use point-slope when slope-intercept and standard form are required. Also, slope-intercept seems easier to work with.
Cool.
Steps:
x - y + 2 = 0
x - y = - 2
- y = - x - 2
y = (- x - 2)/(-1)
y = x + 2
The negative reciprocal of 1 is - 1. This is our slope.
y - 1 = -(x - 3)
y - 1 = - x + 3
y = - x + 3 + 1
y = - x + 4
4. Express the equation in the form Ax + By + C = 0.
x + y - 4 = 0
FAQ: Find an equation of the line that is perpendicular to x - y + 2 = 0
What is the equation of a line?
The equation of a line is a mathematical representation of a straight line. It is typically written in the form y = mx + b, where m is the slope of the line and b is the y-intercept.
How do you find the equation of a line?
The equation of a line can be found using two points on the line. First, calculate the slope using the formula (y2 - y1)/(x2 - x1). Then, plug in the slope and one of the points into the slope-intercept form (y = mx + b) to solve for b. The resulting equation will be the equation of the line.
What is the significance of the slope in the equation of a line?
The slope in the equation of a line represents the rate of change or steepness of the line. A positive slope indicates the line is increasing, while a negative slope indicates the line is decreasing. A slope of zero indicates a horizontal line.
Can the equation of a line be used to graph the line?
Yes, the equation of a line can be used to graph the line. The slope and y-intercept can be used to plot the first two points, and then the line can be extended by using the slope to find additional points.
What is the difference between the slope-intercept form and the standard form of the equation of a line?
The slope-intercept form is written as y = mx + b, while the standard form is written as Ax + By = C. The main difference is that the standard form can represent all types of lines (including vertical and horizontal lines) while the slope-intercept form can only represent non-vertical lines. Additionally, the standard form is often used in algebraic equations, while the slope-intercept form is more commonly used for graphing.
