Find an expression for the electric potential at P
In summary, Keith attempted to solve an electric potential equation using k_e, lambda, a, b, and L. However, he ran into an error when integrating. He suggests using a change of variable, u=a+x, to make the process easier.
Keithkent09
33
The thin, uniformly charged rod shown in the figure below has a linear charge density λ. Find an expression for the electric potential at P. (Use k_e for ke, lambda for λ, a, b, and L as necessary.)
dV=k*dq/r
lambda*dx=dq
I integrated using the above equations and went from 0 to L. I thought this was the right way to do it but I keep getting the wrong answer.
Hello Keithkent09.
First: Show us your work and what you got for your integral.
When you integrate your potential equation you are integrating over the
location of charge correct? The integration does not happen from 0 to L. Your
charge location is not from 0 to L do you see? What should it be?
the integral of (k*dq)/r=(k*lambda+dx)/r
r=sqrt(b^2+(a+x)^2) so...
k*lambda*dx/(sqrt(b^2+(a+x)^2))...and was not sure what to do after this
The next step would be to do the integral. However ...
...here is a suggestion: let x=0 at the point directly below P. That will simplify the integral somewhat. Of course, this will change the limits on x: instead of 0 to L it will be ____ to ____ instead.
Will the limits be from 0 to a+L?
Also if x=0 under point P how does that make the integral any easier, does that mean that x is thrown out in the integral and all that remains is the dx?
If x=0 under point P, then the rod will lie between x=a and x=a+L, right?
Well, set up the integral, using the approach you did before:
dV=k*dq/r
lambda*dx=dq
What expression do you get for the integral in this case?
is it just the integral of (k*lambda*dx)/(sqrt(a^2+b^2) from a to a+L?
Not quite, the (sqrt(a^2+b^2) part is wrong. There should be an x in there somewhere.
Note, this term is equivalent to r, the distance from point P to some point along the wire. The point on the wire would be a distance x from the origin directly below P.
Earlier I said that the denominator was sqrt(b^2+(a+x)^2) i do not understand why the placement of x=0 changes that up.
Never mind, let's go back to your expression which was correct and not confusing you:
This needs to be integrated from x=0 to x=L.
Try looking it up in a table of integrals.
The following might be useful for doing this integral: try a change of variable, u=a+x.
Related to Find an expression for the electric potential at P
1. What is an electric potential?
Electric potential is a measure of the amount of electric potential energy that a unit charge has at a specific point in an electric field. It is often described as the amount of work required to move a unit positive charge from infinity to that point.
2. How is electric potential different from electric field?
While electric field measures the force per unit charge at a point in an electric field, electric potential measures the energy per unit charge at a point. Electric potential is a scalar quantity, while electric field is a vector quantity.
3. What is the formula for electric potential?
The formula for electric potential at a point P is V = kQ/r, where k is the Coulomb's constant, Q is the charge creating the electric field, and r is the distance between the point P and the charge Q.
4. How do you find the electric potential at a point in an electric field?
To find the electric potential at a point in an electric field, you can use the formula V = kQ/r, where k is the Coulomb's constant, Q is the charge creating the electric field, and r is the distance between the point and the charge. You can also use the integral form of the formula, V = -∫E⋅dr, where E is the electric field and dr is the displacement from the reference point to the point P.
5. What factors affect the electric potential at a point?
The electric potential at a point is affected by the amount and distribution of charge creating the electric field, as well as the distance between the point and the charge. It is also affected by the medium in which the electric field exists, with different materials having different electric permittivity values that affect the strength of the electric field.
