Find and simplify the derivative (quotient rule)
anonymity
find the derivative of (x2 - 3)4/(2x3+1)3
and simplify
as far as i could get was 8x(x2-3)3-18x2(2x3+1)2/(2x3+1)6
which is not simplified.
How can you simplify something like this? Is there a systematic way to approach it?
In general, what is the best method to approach really messy derivatives (such as this one, or any other that can be manipulated by algebra)?
Check your calculation: u=(x^{2}-3)^{4} and v=(2x^{3}+1)^{3}, then:
<br /> \frac{du}{dx}=8x(x^{2}-3)^{3}\quad\frac{dv}{dx}=18x^{2}(2x^{3}+1)^{2}<br />
From here the algebra is doable.
Doh. Thanks lol
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
