Find and Sketch the Domain of a Function
In summary, the domain of a function is the set of all possible input values for which the function is defined. To find the domain, restrictions on the input values must be identified, and the domain is all real numbers except for the restricted values. Some common types of functions with restricted domains include rational functions, square root functions, and logarithmic functions. A function can have an infinite domain, meaning there are no restrictions on the input values. To sketch the domain on a graph, a number line can be used with restricted values marked as open circles and the remaining values connected with a line.
cosmos42
ƒ(x,y) = √y + √[25-x2-y2]
Quadratic
The expression for f(x,y) is defined as long as x2 + y2 ≥ 25 and y ≥ 0 because of the square roots we can't have negative numbers. {(x,y) ∈ ℝ2 : y ≥ 0 and x2 + y2 ≥ 25} I'm not sure how I'd represent it graphically.
What is the shape of the region of the number plane that satisfies ##x^2+y^2\leq 25##?
What is the shape of the region of the number plane that satisfies ##y\geq 0##?
What is the shape of the intersection of those two regions?
Related to Find and Sketch the Domain of a Function
1. What is the domain of a function?
The domain of a function is the set of all possible input values for which the function is defined. In other words, it is the set of all x-values that can be plugged into the function to produce a valid output.
2. How do you find the domain of a function?
To find the domain of a function, you must first identify any restrictions on the input values. This can include restrictions such as division by zero or taking the square root of a negative number. Once you have identified these restrictions, the domain is all real numbers except for the values that are restricted.
3. What are some common types of functions with restricted domains?
Some common types of functions with restricted domains include rational functions, square root functions, and logarithmic functions. These functions have restrictions on the input values due to the nature of their equations.
4. Can a function have an infinite domain?
Yes, a function can have an infinite domain. This means that there are no restrictions on the input values and the function is defined for all real numbers.
5. How do you sketch the domain of a function on a graph?
To sketch the domain of a function on a graph, you can use a number line to represent the input values. Any values that are restricted should be marked as open circles to indicate that they are not included in the domain. The remaining values should be connected with a line to show that they are included in the domain.
