Find angle with given distance and height
In summary, the problem involves finding the angle of a projectile shot from a device on top of a desk, given the variables x, y, and v. The relevant equations are y=vyot+(½)ayt2, x = vxot, vsinΘ = vyo, and vcosΘ = vxo. Using trig identities, the attempt at a solution involved manipulating these equations to isolate Θ, but the individual steps were not clear. The use of the quadratic equation may also be helpful in solving for Θ.
brycenrg
95
You have a device that shoots an object at an angle, on top of a desk.
You have x,y and v solve for the angle.
Origin is at the top of the desk.
y=vyot+(½)ayt2
x = vxot
vsinΘ = vyo
vcosΘ = vxo
y= vsinΘt + (1/2)at^2
x = vcosΘt → t = x/(vcosΘ)
y = x*(vsinΘ)/(vcosΘ) +(1/2)a(x/(vcosΘ))^2
y = xtanΘ + (a/2)*((x^2)/(v^2cos^2Θ))
from here i moved cos^2Θ to the left and changed tanΘ into sincos but I don't know how to isolate the Θ by itsself.
Does anyone have any ideas? I know quadratic equation can be used but i don't know how to change it for Θ
Any help is appreciated.[/B]
Hi bryce:
Your title says you want the angle given the distance and height. Your problem statement does not mention a distance and height, ether as a number or as a variable. I suppose you might have in mind that x is distance and y is height, but then what has the desk got to do with it?
Regards,
Buzz
Related to Find angle with given distance and height
1. How do you find the angle with a given distance and height?
To find the angle with a given distance and height, you can use the trigonometric functions of tangent or arctangent. Tangent is the ratio of the opposite side to the adjacent side of a right triangle, and arctangent is the inverse of tangent. By plugging in the given distance and height values into the appropriate function, you can find the angle.
2. What is the relationship between distance, height, and angle in a right triangle?
In a right triangle, the tangent of an angle is equal to the ratio of the opposite side to the adjacent side. This means that the angle is directly related to the distance and height. As the distance and height change, the angle will also change accordingly.
3. Can a right triangle have multiple angles with the same distance and height?
No, a right triangle can only have one unique angle with a given distance and height. This is because the tangent function is a one-to-one function, meaning that each input has only one output. Therefore, for a given distance and height, there can only be one corresponding angle.
4. How can finding the angle with a given distance and height be useful in real-life situations?
Finding the angle with a given distance and height can be useful in various real-life situations, such as construction, engineering, and navigation. For example, if you know the distance and height of a building, you can use the angle to determine the slope of the roof or the angle of elevation for a crane to reach the top of the building.
5. Is it possible to find the angle with a given distance and height without using trigonometric functions?
Yes, it is possible to find the angle with a given distance and height without using trigonometric functions by using basic geometry principles. One method is to use the Pythagorean theorem to find the length of the hypotenuse, and then use the inverse sine function to find the angle. However, this method may not be as accurate or efficient as using trigonometric functions.
13K
