MHB Find angles when circumference is divided into 5 unequal parts
The discussion revolves around a problem from an old trigonometry textbook that involves dividing a circle's circumference into five unequal parts in arithmetic progression (A.P.). The greatest part is specified to be six times the least, and the angles subtended at the center are to be calculated in radians. Participants clarify that A.P. indicates each segment increases by a constant difference. The correct angles are provided as fractions of π, specifically $$\frac{4\pi}{35},\frac{9\pi}{35},\frac{14\pi}{35}, \frac{19\pi}{35},\frac{24\pi}{35}$$ radians. Understanding A.P. is crucial for solving the problem accurately.
Ragnarok7
Hello, I am using a very old textbook from 1895, Loney's Trigonometry, which poses the following problem:
If the circumference of a circle be divided into 5 parts, which are in A.P., and if the greatest part be 6 times the least, find in radians the magnitudes of the angles that the parts subtend at the centre of the circle.
The answers are given as $$\frac{4\pi}{35},\frac{9\pi}{35},\frac{14\pi}{35}, \frac{19\pi}{35},\frac{24\pi}{35}$$ radians.
The trouble is that I have no idea what is meant by "5 parts, which are in A.P.". There is no diagram and the only reference to points A and P I can find is in a much earlier diagram, where AP is an arc subtending an angle of one radian. Does anyone have any ideas, based on the specifications of the problem? Thank you!
Mathematics news on Phys.org
A.P. means Arithmetic Progression. In other words, each piece differs from the previous one by a constant amount.
Ah, thank you so much! I couldn't imagine what it meant, though it's quite clear now.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
