MHB Find Area of Lemniscate Bounded by Circle: r^2=6sin(2theta) & r=sqrt(3)
The discussion focuses on calculating the area of the lemniscate defined by r^2=6sin(2θ) that lies outside the circle r=sqrt(3). The area is determined by first identifying the intersection points of the two curves, which occur at θ=π/12 and θ=5π/12. By leveraging the symmetry of the lemniscate, the area is computed by integrating the difference between the lemniscate and circle equations over the specified limits. The final calculated area is A=3√3−π, correcting the initial claim of 15π/2 being incorrect. This method emphasizes the importance of proper integration and understanding curve intersections in polar coordinates.
MarkFL
MHB
Here is the question:
Find the area of the lemniscate...?
Find the area inside the lemniscate r^2=6sin(2theta) and outside the circle r=sqrt(3).
I keep getting 15pi/2, but I am told this is wrong...
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Pete,
First, let's look at a plot of the area to be found:
We see that by symmetry, we may double the computation of the first quadrant area to get the total area. First, let's compute the limits of integration by determining at what angles the two curves have intersections in this quadrant:
$$r^2=6\sin(2\theta)=3$$
$$\sin(2\theta)=\frac{1}{2}$$
$$2\theta=\frac{\pi}{6},\,\frac{5\pi}{6}$$
$$\theta=\frac{\pi}{12},\,\frac{5\pi}{12}$$
Hence the area $A$ is given by:
$$A=2\cdot\frac{1}{2}\int_{\frac{\pi}{12}}^{\frac{5\pi}{12}} 6\sin(2 \theta)-3\,d\theta$$
$$A=3\int_{\frac{\pi}{12}}^{\frac{5\pi}{12}}\sin(2 \theta)\,2\,d\theta-3\int_{\frac{\pi}{12}}^{\frac{5\pi}{12}}\,d\theta$$
On the first integral, we may use the substitution:
$$u=2\theta\,\therefore\,du=2\,d\theta$$
and we have:
$$A=3\int_{\frac{\pi}{6}}^{\frac{5\pi}{6}}\sin(u)\,du-3\int_{\frac{\pi}{12}}^{\frac{5\pi}{12}}\,d\theta$$
Applying the FTOC, we obtain:
$$A=-3\left[\cos(u) \right]_{\frac{\pi}{6}}^{\frac{5\pi}{6}}-3\left[\theta \right]_{\frac{\pi}{12}}^{\frac{5\pi}{12}}$$
$$A=-3\left(-\frac{\sqrt{3}}{2}-\frac{\sqrt{3}}{2} \right)-3\left(\frac{5\pi}{12}-\frac{\pi}{12} \right)$$
$$A=3\sqrt{3}-\pi$$
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
10K
