MHB Find Area of Polygon: Simpler Method?
  • Thread starter Thread starter Blandongstein
    Area Polygon
The discussion centers on finding the area of a polygon defined by the points (3,5), (5,11), (14,7), (8,3), and (6,6). A simpler method than dividing the polygon into triangles is suggested: the Shoelace formula, which provides a systematic way to calculate the area based on the coordinates of the vertices. The formula is detailed, showing how to compute both positive and negative terms from the coordinates. Using the Shoelace formula for the given points results in an area of 41.5. Alternative methods, such as using trapezoids, are also mentioned for calculating the area.
Blandongstein
Find the area of the polygon formed by the points (3,5), (5,11), (14,7), (8,3), and (6,6).
I can find the area of the polygon by dividing it into 3 triangles and then finding area of each triangle separately. I want to know if there is any simpler way of doing this.
Mathematics news on Phys.org
Hello DigitalComputer! Such problems are solved using the shoelace formula. If $A_r (x_r , y_r); \ r = 1,2,3, \cdots , n$ be the vertices of a polygon, taken in order then the area of the polygon $A_1 A_2 A_3 \cdots A_n$ is given by
\[\text{area}= \Bigg|\frac{1}{2}\left( \sum_{r=1}^{n-1} \begin{vmatrix}x_i & y_i \\ x_{i+1} & y_{i+1}\end{vmatrix}+\begin{vmatrix}x_n & y_n \\ x_{1} & y_{1}\end{vmatrix}\right) \Bigg|\]
Hi DigitalComputer, :)
To elaborate more on the Shoelace method, suppose you have a set of points, \((x_i,\,y_i)\mbox{ where }i=1,\,2,\,\cdots,\,n\), which are vertices of a polygon. Then the Shoelace formula is,
\[A={1 \over 2}|x_1y_2 + x_2y_3 + \cdots + x_{n-1}y_n + x_ny_1 - x_2y_1 - x_3y_2 - \cdots - x_ny_{n-1} - x_1y_n|\]
where \(A\) is the area of the polygon.
Note that in the Shoelace formula, the positive terms are obtained by the following manner;
The first \(x\) coordinate is multiplied by the second \(y\) coordinate, the second \(x\) coordinate is multiplied by the third \(y\) coordinate and so on. Finally the nth, \(x\) coordinate is multiplied by the first \(y\) coordinate.
And the negative terms are obtained by,
The second \(x\) coordinate is multiplied by the first \(y\) coordinate, the third \(x\) coordinate is multiplied by the second \(y\) coordinate and so on. Finally the first \(x\) coordinate is multiplied by the nth, \(y\) coordinate.
In your case, you have the points, \((3,5),\,(5,11),\, (14,7),\, (8,3)\mbox{ and }(6,6)\). Therefore by the Shoelace formula,
\[A=\frac{1}{2}|(3\times 11)+(5\times 7)+(14\times 3)+(8\times 6)+(6\times 5)-(5\times 5)-(14\times 11)-(8\times 7)-(6\times 3)-(3\times 6)|=41.5\]
Kind Regards,
Sudharaka.
Hello, DigitalComputer!
Find the area of the polygon formed by the points;
. . A (3,5), B(5,11), C(14,7), D(8,3), and E(6,6).
I use trapezoids . . .
Code:
      |           B
      |           o
      |       *   :   E   *
      |      *    :   o     *
      |    *  *   :   : *       o C
      | A o       :   :  *   *  :
      |   :       :   :   o     :
      |   :       :   :   D     :
      |   F       G   H   I     J
First, I find the total area under the tent-shaped figure:
. . trapezoids ABGF + BCJG.
Then I subtract the areas of the three lower trapezoids:
. ..AEHF + EDIH + DCJI
Thank You!
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
