Find b, a and f(x) for the definite integral
In summary, Homework Equations state that n=3 because there are three terms in the equation, and that a is 2 and b is 4 because of (2+0*(4/3))^2 and because (b-a)/n=Δx. This gives n=3 and Δx=2. PainGuy found that b=4 because of (1+1*(4/3))^2*4/3=4.
Painguy
120
Three terms are used in a left hand sum to approximate the integral of ∫a to b f(x)dx
((2+0*(4/3))^2 * 4/3) + ((1+1*(4/3))^2 * 4/3) + ((2+2*(4/3))^2 * 4/3)
find a possible value of b and a, and f(x
Ʃ Δx(f(a+Δxi))
based on the the given summation I figured f(x)=x^2
and I want to say a is 2 and b is 4 because of (2+0*(4/3))^2 and because (b-a)/n=Δx. so that would mean n = 3
but the part that says ((1+1*(4/3))^2 * 4/3) is confusing me.
Well you have three terms in the equation - so write out (expand) the summation in symbols to three terms. Write out the numerical equation directly undernieth this. Compare them.
n=3 because there are three terms ... but you have made a fence-post error in computing ##\Delta x##.
I don't understand what you mean. I have 3 terms? (i, Δx, and a) right?
i know what Δx is, but I'm stumped on what to put for a, and how to get it.
Not what I meant.
I am somewhat restricted by trying not to do the problem for you ;)
You have an expression with a bunch of numbers in it - that expression has three terms in it like this: term1 + term2 + term3
You also have an expression with symbols in it after a big Greek letter sigma - it is a summation. You have to match this one up with the one with all the numbers.
You should expand that summation into the corresponding three terms ... that will give you something to compare the first expression to. Then you will see where you have made your mistake and you'll see how to find the correct delta-x and b.
Do you not know what a "fence-post error" is?
Look it up. hint: ##n \neq 3##.
Inspecting the expression,
((2+0*(4/3))^2 * 4/3) + ((1+1*(4/3))^2 * 4/3) + ((2+2*(4/3))^2 * 4/3) ,
it's quite easy to determine a, n, and Δx .
What do you get for those values?
Recap - we have:$$\int_a^b f(x)dx \approx \sum_{i=0}^n f(a+i\Delta x)\Delta x =\left (2+0\cdot\frac{4}{3}\right )^2 \frac{4}{3} + \left (1+1\cdot\frac{4}{3}\right )^2\frac{4}{3} + \left ( 2 + 2\cdot\frac{4}{3}\right )^2\frac{4}{3}=T_1 + T_2 + T_3$$... the task is to find ##a## and ##\Delta x## and ##b##.
painguy had left off the indexes for the sum - which are an important clue.
I still think that expanding the sum symbolically will be useful to understanding the problem.
You can relate ##b## to ##a##, ##\Delta x## and ##n##, and find it that way but you don't really need to. When painguy did this, he got the wrong value for n.
I do have a bit of a problem with that second term [1] - which is also confusing painguy -I think it is supposed to be $$T_2= \left (2+1\cdot\frac{4}{3}\right )^2\frac{4}{3} $$
Apart from that it is a matter of reading off the values.
[1] ... otherwise the three terms are inconsistent.
Simon Bridge said:
Recap - we have:$$\int_a^b f(x)dx \approx \sum_{i=0}^n f(a+i\Delta x)\Delta x =\left (2+0\cdot\frac{4}{3}\right )^2 \frac{4}{3} + \left (1+1\cdot\frac{4}{3}\right )^2\frac{4}{3} + \left ( 2 + 2\cdot\frac{4}{3}\right )^2\frac{4}{3}=T_1 + T_2 + T_3$$... .
I think I see where one problem could be.
I usually see the Riemann sum written with n being the number of intervals into which [a,b] is partitioned.
So for a left hand sum, I would write [itex]\displaystyle \int_a^b f(x)dx \approx \sum_{i=0}^{n-1} f(a+i\Delta x)\Delta x \ .[/itex]
And for a right hand sum [itex]\displaystyle \int_a^b f(x)dx \approx \sum_{i=1}^{n} f(a+i\Delta x)\Delta x \ .[/itex]
So I would say n=3.
Painguy still has b wrong.
As for the second term -- I think that's just a typo.
Fair enough. However - PainGuy says:
PainGuy said:
(b-a)/n=Δx
... which, at face value, suggests that n is the number of ##\Delta x##'s between a and b. Which is not 3.
I maintain this is a fence-post error either way.
I suspect that the confusion here is the source of the matter.
I agree about the second term being a typo. I was hoping to get PainGuy to expand the sum and see that as the most likely explanation: there is nothing like the confidence you get from showing the question is wrong ;)
Now we need to hear back from OP :)
Simon Bridge said:
Fair enough. However - PainGuy says: ... which, at face value, suggests that n is the number of ##\Delta x##'s between a and b. Which is not 3.
It looks like 3 Δx's to me.
1st one's is multiplied by zero ... am I talking at cross purposes again?
I've been doing a+(n-1)Δx = b having the sum slightly overrun. But of course the 4/3 makes more sense the way you tell it ... and I owe OP an apology :( <sigh>
It would be more:
if ##\Delta x = (b-a)/n## then do the algebra first (solve for b), then plug in the numbers.
You know what it is? I've been doing too many MATLAB simulations where I'm sampling a function over n discrete points, including start an finish, which means I need n-1 intervals.
I'm going to go have a stiff drink!
I'll drink to that !
FAQ: Find b, a and f(x) for the definite integral
What is the purpose of finding b, a, and f(x) for a definite integral?
Finding b, a, and f(x) for a definite integral helps to determine the area under a curve between two given points on a graph. It is a fundamental concept in calculus that is used to solve problems involving rates of change and accumulation.
How do you find the values of b, a, and f(x) for a definite integral?
To find the values of b, a, and f(x) for a definite integral, you need to first determine the limits of integration (b and a) and then evaluate the integrand (f(x)) at those limits.
What is the difference between b and a in a definite integral?
The value of b represents the upper limit of integration, while the value of a represents the lower limit of integration. These limits define the range over which the integral is being evaluated.
How do you interpret the value of f(x) in a definite integral?
The function f(x) in a definite integral represents the rate of change of the dependent variable (y) with respect to the independent variable (x). It can also be interpreted as the height of each infinitesimal rectangle that makes up the area under the curve.
Can you find b, a, and f(x) for a definite integral with a non-linear curve?
Yes, the process for finding b, a, and f(x) for a definite integral is the same regardless of whether the curve is linear or non-linear. The only difference is that the integral may be more difficult to solve for non-linear curves, requiring more advanced techniques such as substitution or integration by parts.
