MHB Find Balloon Height: Darshan Amin's Question on Yahoo Answers
  • Thread starter Thread starter MarkFL
    Balloon Height
The discussion centers on a mathematical problem involving the height of a balloon's center based on its radius and angles subtended at the observer's eye. The solution involves deriving the height using trigonometric relationships, specifically the sine function for angles β and α. The key equations show that the height (h) can be expressed as h = r*sin(β)*cosec(α/2). A diagram is referenced to aid understanding of the relationships between the variables. The thread provides a clear proof of the height formula, confirming its accuracy.
MarkFL
MHB
Here is the question:
A round balloon of radius r subtends an angle α at the eye of observer while the angle of elevation of its?
A round balloon of radius r subtends an angle α at the eye of observer while the angle of elevation of its centre is β.prove that the height of the centre of the balloon is r*sinβ*cosecα*1/2
I have posted a link there to this thread so the OP can view my work.
Mathematics news on Phys.org
Hello Darshan Amin,
Please consider the following diagram:
From this we see:
(1) $$\sin(\beta)=\frac{h}{d}\implies h=d\sin(\beta)$$
(2) $$\sin\left(\frac{\alpha}{2} \right)=\frac{r}{d}\implies d=r\csc\left(\frac{\alpha}{2} \right)$$
Substituting for $d$ from (2) into (1) we obtain:
$$h=r\csc\left(\frac{\alpha}{2} \right)\sin(\beta)=r\sin(\beta) \csc\left(\frac{\alpha}{2} \right)$$
Shown as desired.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
