Find: c/(a + b) + b/(a + c) = ?
  • MHB
  • Thread starter Albert1
In summary, the value of $\dfrac {c}{a+b}+\dfrac {b}{a+c}$ is equal to $1$, which can be found using the cosine formula and the relationship between the side lengths of a triangle. This value can be determined geometrically without using any calculations.
Albert1
1,221
$\triangle ABC$ has side lengths $a,b,c$
$\text{if}\,\, \angle A=60^o$
find :
$\dfrac {c}{a+b}+\dfrac {b}{a+c}=?$
Mathematics news on Phys.org
Re: find :c/(a+b) + b/(a+c) =?
Using Cosine formula $\displaystyle \cos (A) = \frac{b^2+c^2-a^2}{2bc}$
Now Given $A = 60^0$ . So $\displaystyle \frac{1}{2} = \frac{b^2+c^2-a^2}{2bc}$
So $b^2+c^2-a^2 = bc \Rightarrow b^2+c^2 = a^2+bc$
Now Given $\displaystyle \frac{c}{a+b}+\frac{b}{a+c} = \frac{c\cdot(a+c)+b\cdot (a+b)}{(a+b)\cdot (a+c)}$
So $\displaystyle = \frac{c^2+ac+b^2+ab}{a^2+ab+bc+ca} = \frac{a^2+ab+bc+ca}{a^2+ab+bc+ca} = 1$
Using $b^2+c^2 = a^2+bc$
Can someone find its value using geometry only ?
I would approach this problem by first recognizing that the given information involves a triangle with side lengths a, b, and c, and an angle of 60 degrees. I would then use my knowledge of geometry and trigonometry to solve for the unknown value of the expression $\dfrac {c}{a+b}+\dfrac {b}{a+c}$.
Using the Law of Cosines, I can determine that $c^2 = a^2 + b^2 - 2ab\cos 60^o$. Simplifying this equation, I get $c^2 = a^2 + b^2 - ab$. Similarly, I can use the Law of Sines to determine that $\dfrac{c}{\sin 60^o} = \dfrac{a}{\sin B}$. Since $\sin 60^o = \dfrac{\sqrt{3}}{2}$ and $\sin B = \dfrac{b}{c}$, I can substitute these values into the equation to get $\dfrac{2c}{\sqrt{3}} = \dfrac{a}{b}$. Rearranging this equation, I get $c = \dfrac{a\sqrt{3}}{2b}$.
Now, I can substitute this value of c into the original expression to get $\dfrac {\dfrac{a\sqrt{3}}{2b}}{a+b}+\dfrac {b}{a+\dfrac{a\sqrt{3}}{2b}}$. Simplifying this further, I get $\dfrac{\sqrt{3}}{2(a+b)}+\dfrac{2b}{2ab+a\sqrt{3}}$. Finally, I can combine these fractions to get $\dfrac{\sqrt{3}(2ab+a\sqrt{3}+2b^2)}{2(a+b)(2ab+a\sqrt{3})}$. This is the final answer for the expression $\dfrac {c}{a+b}+\dfrac {b}{a+c}$ when $\angle A = 60^o$.
FAQ: Find: c/(a + b) + b/(a + c) = ?
What is the purpose of finding c/(a + b) + b/(a + c) = ?
The purpose of finding this equation is to solve for the value of c, which is unknown. It is often used in algebraic equations to find the value of a variable.
How do you solve for c in c/(a + b) + b/(a + c) = ?
To solve for c, you can use algebraic methods such as combining like terms, distributing, and isolating the variable on one side of the equation. The specific steps may vary depending on the complexity of the equation.
Can you provide an example of solving for c in c/(a + b) + b/(a + c) = ?
Sure, let's say we have the equation 3/(x + 2) + 2/(x + 3) = 1. First, we will combine the fractions by finding a common denominator of (x + 2)(x + 3). This gives us 3(x + 3) + 2(x + 2) = (x + 2)(x + 3). Simplifying further, we get 5x + 15 = x^2 + 5x + 6. Moving all terms to one side, we get x^2 + 6 = 0. Solving for x, we get x = ±√(-6). Therefore, there are no real solutions for this equation and c cannot be solved.
Are there any restrictions or limitations for solving c/(a + b) + b/(a + c) = ?
Yes, there may be restrictions or limitations depending on the context of the equation. For example, if the variables represent real numbers, then the denominators cannot be equal to zero. Additionally, there may be specific conditions or assumptions given in the problem that must be followed in order to solve for c.
Is there a specific formula or method for solving c/(a + b) + b/(a + c) = ?
There is no specific formula for solving this equation, as it is a part of algebraic manipulation and solving for an unknown variable. However, there are various strategies and techniques that can be used, such as factoring, substitution, or using the quadratic formula in certain cases.
