Find Change in the Electric Potential
In summary: B.)U=qVC.)Kf-Ki+u=0.5mv^2+u=0(b)Kf-Ki+u=0(a) Electric potential is measured in volts. You were given V/m and metres. Just combine them to get volts [Joules per Coulomb; which you will need for part (b)]so what I started doing was right... (40000V/m)(.3m) =12000 Vwhen I put in that answer it says I am wrong :(Potential difference is given in volts. Electric fields are measured in
fal01
A proton is released from rest in a uniform
electric field of magnitude 40000V/m di-
rected along the positive x axis. The proton
undergoes a displacement of 0.3 m in the di-
rection of the electric field
The mass of a proton is 1.672623×10−27 kg
A.Find the change in the electric potential
if the proton moves from the point A to B.
Answer in units of V.
B.Find the change in potential energy of the
proton for this displacement. Answer in units
of J.
C.Apply the principle of energy conservation to
find the speed of the proton after it has moved
0.5 m, starting from rest. Answer in units of
m/s.
V=Ed
U=qV
Kf-Ki+u=0
k=.5mv^2
Q
A.) E=40000 V/m
d=.3m
mp=1.672623*10^-27kg
q=1.60218*10^-19
V=Ed
V=(40000)(.3)=12000V ---but that is wrong
B.)
U=qV
C.)
Kf-Ki+U=0
.5mv^2+U=0
of J.C.Apply the principle of energy conservation to
m/s.
V=Ed
U=qV
Kf-Ki+u=0
k=.5mv^2
Q
A.) E=40000 V/m
d=.3m
q=1.60218*10^-19
V=Ed
B.)
U=qV
C.)
Kf-Ki+U=0
.5mv^2+U=0
Potential difference is given in volts. Electric fields are measured in V/m.
E = dV/dx, so your change in potential dV = E*dx, which does match your working. However, since the electric field is doing work on the particle by pushing it, the particle is losing potential energy, not gaining it: your sign should be negative, I think.
Thanks! I was just missing the negative sign.
Related to Find Change in the Electric Potential
1. What is electric potential?
Electric potential is a measure of the work done per unit charge by an electric field in moving a charge from one point to another. It is also known as voltage and is measured in volts.
2. How is change in electric potential calculated?
The change in electric potential is calculated by taking the difference between the final and initial electric potential values. This is represented by the formula ΔV = Vf - Vi, where ΔV is the change in electric potential, Vf is the final potential, and Vi is the initial potential.
3. What factors affect the change in electric potential?
The change in electric potential is affected by the distance between two points, the magnitude of the electric field, and the charge of the object experiencing the electric field. It is also affected by the direction of the electric field and the relative position of the positive and negative charges.
4. How does change in electric potential relate to work done?
The change in electric potential is directly related to the work done by an electric field on a charge. This can be represented by the formula W = qΔV, where W is the work done, q is the charge, and ΔV is the change in electric potential.
5. What is the unit of measurement for change in electric potential?
The unit of measurement for change in electric potential is volts (V). It can also be expressed in other units such as joules per coulomb (J/C) or newtons per coulomb (N/C).
