Find charge and radius of conducting spheres given voltage and electr
In summary, the electric potential immediately outside a charged conducting sphere can be determined by using the equations 200=kq/r and 150=kq/(r+0.1) where r is the radius of the sphere and q is the charge on it. By solving these equations, the radius is found to be 0.3m and the charge to be 6.67x10^-9C. Similarly, for another charged conducting sphere with electric potential of 210 V and electric field of 400 V/m, the equations 210=kq/r and 400=q/(4pi(r+0.1)^2) can be used to determine the radius and charge. However, there may be two solutions due to the squared
g-racer
The electric potential immediately outside a charged conducting sphere is 200 V, and 10.0 cm farther from the center of the sphere the potential is 150 V. Determine (a) the radius of the sphere and (b) the charge on it. The electric potential immediately outside another charged conducting sphere is 210 V, and 10.0 cm farther from the center the magnitude of the electric field is 400 V/m. Determine (c) the radius of the sphere and (d) its charge on it. (e) Are the answers to parts (c) and (d) unique?for the first part I said 200=kq/r and 150 =kq/(r+0.1) to solve for r=0.3m I then input this in and solved for q=6.67x10^-9C
For the second part I said 210=kq/r and 400=q/(4pi(r+0.1)^2) and get r=-0.1 which cannot be right! help would be appreciated thanks
Hint: r appears squared - so you should have two solutions.
I know there should be two but with 1600pi r^2+(320pi-210/k)r +16pi I only get r=-0.1
The equation in red should be 400=kq(r+0.1)2. (K=1/(4piε0), you missed ε0)
ehild
You are saying that from: 1600pi r^2+(320pi-210/k)r +16pi = 0
you only get r=-0.1 ?
But you can't...
The discriminant is (320pi-120/k)^2-4(1600pi)(16pi) < 0 ... so you should have no roots at all.
This means you set up the equation wrong.
ehild may have spotted the answer - you may have made other errors: recheck your working.
I'd start from scratch:
So you have charge q giving voltage V at radius R, and electric field E at radius R+r.
You must find q and R given V, E, and r. Leave the numbers to after doing the algebra.
shortcut: Write the equations in the form kq=...
ok thanks so much I had forgot the e in the equation
so setting equal for kq I get 210r=400(r+0.1)^2 but then I still get negative square roots...?
Please show your working - the trouble is either algebra or arithmetic.
Please follow advise and wait till after the algebra is done to plug the numbers in.
Start with your ##Vr=E(r+d)^2## - divide through by E, put in standard form and use the quadratic equation.
Then put in: V=210V, E=400V/m, d=0.1m
ok so 210=kq/r and 400=kq/(r+0.1)^2 setting equal gives 210r=400(r+0.1)^2 which gives the quadratic 400r^2+80r+4=210r which gives 400r^2-130r+4 ...nevermind I had put -40r for some reason! thanks so much
This is why I kept telling you to put the numbers in last.
If you do all your algebra with the variables this sort of mistake is much less common and much easier to spot when it does happen.
I realize that many students are uncomfortable with this approach but it is worth it in the long run: not all your problems will be this simple.
Related to Find charge and radius of conducting spheres given voltage and electr
1. How do you find the charge of a conducting sphere given a voltage?
To find the charge of a conducting sphere, you can use the equation Q = CV, where Q is the charge, C is the capacitance, and V is the voltage.
2. Can the charge of a conducting sphere be negative?
Yes, the charge of a conducting sphere can be negative. This indicates that the sphere has an excess of electrons, which have a negative charge.
3. How is the radius of a conducting sphere related to its charge?
The radius of a conducting sphere is directly proportional to its charge. This means that as the charge increases, the radius of the sphere will also increase.
4. What is the unit for charge?
The unit for charge is Coulomb (C).
5. Can the voltage of a conducting sphere be changed?
Yes, the voltage of a conducting sphere can be changed by connecting it to a different voltage source. This will in turn change the charge and radius of the sphere.
