MHB Find Complex Conjugate of 1/(1+e^(ix))
To find the complex conjugate of the expression 1/(1+e^(ix)), the first step is to replace all instances of i with -i, resulting in 1/(1+e^(-ix)). Rationalizing the denominator leads to the expression (1+e^(ix))/(2+2cos(x)), which differs slightly from the original poster's result. Another method involves multiplying by e^(ix/2) to achieve symmetry, yielding the final answer of 0.5 sec(x/2) e^(i(x/2)). The discussion emphasizes the importance of correctly manipulating complex numbers to derive accurate results.
nicodemus1
Good Day,
I would like to know how to find the complex conjugate of the complex number 1/(1+e^(ix)).
I got (1+e^(-(ix)))/(2+2 cos x) but the solution is 0.5 sec (x/2) e^(i(x/2)).
Any help will be greatly appreciated.
Thanks & Regards
P.S. Apologies for not using LATEX as it was formatting the expressions wrongly
Mathematics news on Phys.org
Well, the first step is to actually conjugate, which is simply to replace all $i$'s with $-i$'s:
$$ \frac{1}{1+e^{ix}} \to \frac{1}{1+e^{-ix}}.$$
Next, one thing we could do is to rationalize the denominator to make the result have a real number in the denominator:
$$ \frac{1}{1+e^{-ix}} \cdot \frac{1+e^{ix}}{1+e^{ix}}
=\frac{1+e^{ix}}{1+e^{ix}+e^{-ix}+1}=\frac{1+e^{ix}}{2+2 \cos(x)}.$$
That's slightly different from your result.
Another approach would be to create symmetry where there isn't any, by multiplying top and bottom by $e^{ix/2}$:
$$\frac{1}{1+e^{-ix}} \cdot \frac{e^{ix/2}}{e^{ix/2}}=\frac{e^{ix/2}}{e^{ix/2}+e^{-ix/2}}= \frac{e^{ix/2}}{2 \cos(x/2)},$$
which is where your book's answer comes from.
nicodemus said:
Good Day,
Thanks & Regards
I would lean towards trying to write your complex number in terms of its real and imaginary parts, then the conjugation is easy...
\displaystyle \begin{align*} \frac{1}{1 + e^{i\,x}} &= \frac{1}{1 + \cos{(x)} + i\sin{(x)}} \\ &= \frac{1 \left[ 1 + \cos{(x)} - i\sin{(x)} \right] }{\left[ 1 + \cos{(x)} + i\sin{(x)} \right] \left[ 1 + \cos{(x)} - i\sin{(x)} \right] } \\ &= \frac{1 + \cos{(x)} - i\sin{(x)} }{ \left[ 1 + \cos{(x)} \right] ^2 + \sin^2{(x)} } \\ &= \frac{1 + \cos{(x)} - i\sin{(x)}}{ 1 + 2\cos{(x)} + \cos^2{(x)} + \sin^2{(x)}} \\ &= \frac{1 + \cos{(x)} - i\sin{(x)} }{ 2 + 2\cos{(x)} } \\ &= \frac{1 + \cos{(x)}}{2\left[ 1 + \cos{(x)} \right] } - i\left\{ \frac{\sin{(x)}}{2 \left[ 1 + \cos{(x)} \right] } \right\} \\ &= \frac{1}{2} - i\left\{ \frac{\sin{(x)}}{2 \left[ 1 + \cos{(x)} \right] } \right\} \end{align*}
So the conjugate is \displaystyle \begin{align*} \frac{1}{2} + i\left\{ \frac{\sin{(x)}}{2 \left[ 1 + \cos{(x)} \right] } \right\} \end{align*}
Yes, it is quite simple actually. I used the approach to express the given complex number in x+iy but I made a careless mistake there.
Thank you very much for all your help and advice.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
