MHB Find cos theta and tan theta using sin theta
Given that sin θ = 4/5, the adjacent side of the triangle is determined to be 3 using the Pythagorean theorem. Consequently, cos θ is calculated as 3/5 and tan θ as 4/3. However, it is noted that if θ is in the second quadrant, the cosine and tangent values would be negative. Therefore, both positive and negative values should be considered based on the quadrant in which the angle lies. This highlights the importance of quadrant consideration in trigonometric calculations.
mathlearn
If sin $$\theta$$ =$$\frac{4}{5}$$ , find cos $$\theta$$ and tan $$\theta$$
Can you help me to solve. :)
Many thanks :)
Mathematics news on Phys.org
Re: Find cos theta and tan theta using sin thetha
Many thanks :)
Hey mathlearn! ;)
The sine is the opposite side divided by the hypotenuse.
What would be the length of the adjacent side, knowing we have a right triangle?
And what would then be the cosine respectively the tangent?
sin $$\theta$$ = $$\frac{opposite side}{hypotenuese}$$
$$\therefore sin $$ $$\theta$$ =$$\frac{4}{5}$$
So applying Pythagoras theorem
Hypotenuse2 = opposite side 2 + adjacent side2
$$5^{2}$$ = $$4^{2}$$ + $$ adjacent side^{2}$$
$$25$$ = $$16$$ + $$ adjacent side^{2}$$
$$25$$ - $$16$$= $$ adjacent side^{2}$$
$$9$$= $$ adjacent side^{2}$$
$$\sqrt{9}$$= $$ \sqrt{adjacent side^{2}}$$
$$3$$= $$adjacent side$$
$$\therefore cos \theta$$ = $$\frac{adjacent side}{hypotenuse }$$$$\therefore cos \theta$$ = $$\frac{3}{5}$$
and
$$\therefore tan \theta$$ = $$\frac{opposite side}{adjacent side}$$
$$\therefore tan \theta$$ = $$\frac{4}{3}$$
Correct I Guess?
Many Thanks :)
Yep. All correct. (Nod)
Actually, it's possible that the angle could be in the second quadrant, in which case the cosine and tangent values would be negative.
Without any information about which quadrant the angle lies, you would need to write both the positive and negative answers.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
