MHB Find cos(x) and sin(x) if angle x has these properties....
  • Thread starter Thread starter Sirmeris1
    Angle Properties
An angle z in standard position with its terminal side in quadrant III cannot be parallel to the line 3x + 4y = 12, as any parallel line through the origin would have a slope of -3/4, which does not allow for points in quadrant III. The definition of an angle in standard position requires the terminal side to connect to the vertex at (0,0), but the slope of the parallel line leads to contradictions regarding quadrant placement. Therefore, it is concluded that such an angle cannot exist under the given conditions. The reasoning presented is sound, confirming the impossibility of the scenario. The discussion effectively highlights the geometric constraints involved in the problem.
Sirmeris1
Find cos(z) and sin(z) if z is an angle in quadrant III (in standard position) and the terminal side of angle z is parallel to the line 3x+4y=12.
I just want to make sure I'm thinking about this correctly:
The definition of an angle in standard position is that the vertex is at (0,0) and the the x-axis is one end of the angle. Now, I'm thinking that the line with which the terminal side coincides MUST contain the point (0,0) because the terminal side of an angle must be connected to it's vertex and by definition the vertex of this angle is at (0,0). My problem lies with the fact that if the angle is in quadrant III (which if I remember correctly is the bottom left corner of the Cartesian plane) then the terminal side must also be in quadrant III and the line that contains that terminal side must be parallel to 3x+4y=12 and must contain the point (0,0). But this is impossible, because if a line has the point (0,0) that is parallel to 3x+4y=12 will have the slope -(3/4), from which we get that the line that contains the terminal side is just y=-(3/4)x, but this line doesn't contain any points in quadrant III (because when x is negative y is positive and thus in quadrant II). Therefore, angle z CANNOT have a terminal side in quadrant III parallel to the line 3x+4y=12 because there exists no parallel line to 3x+4y=12 that contains the point (0,0) that also contains points in quadrant III.
So I'm getting that this question is impossible. Is my reasoning flawed here? Am I missing something? Attached is my graph where the solid line is the given line and the line is the theoretical parallel line. Thank you in advance for any clarifications.
Mathematics news on Phys.org
Hello and welcome to MHB, Sirmeris! (Wave)
I agree with your reasoning, and your conclusion. (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
