Find CTCs in Kerr Metric: Visualizing Spacetime Geometry
In summary, the Kerr metric is an example of a spacetime with closed timelike curves, but these curves only occur inside the inner horizon which is not physically realistic. The exterior part of the Kerr metric does not contain any CTCs and it is not known if it describes the spacetime around an ordinary rotating object. The presence of CTCs in a spacetime can be determined by constructing a coordinate chart with periodic coordinates, as shown in the case of Misner space and Godel spacetime. However, for an arbitrary spacetime, there is no general way to determine the presence of CTCs. The coordinate chart for the Kerr metric does have two periodic coordinates, but the other two are not periodic.
space-time
218
I have been trying to study some differential geometry and some stuff about manifolds in my efforts to learn about closed timelike curves, but thus far it has been a lot of set theory and I have yet to see the "geometry" aspect. What I really want to know is this:
We know how some spacetimes have "boosts", or in other words, they have spacetime geometries where traveling forward along some curve in spacetime will eventually lead you back to the event from whence you started. If such a curve is timelike, then the curve is a CTC. An example of a spacetime with such a boost is Misner space, which seems to have the boost:
(t, x) -> (tcosh(π) + xsinh(π) , xcosh(π) + tsinh(π))
This is the boost that is reported by the Misner space wiki: https://en.wikipedia.org/wiki/Misner_space
Now in the case of Misner space, that boost was just given to me by the wiki. One can see how a boost like this would indicate the existence of closed timelike curves.
However, let's look at a different metric that is known to have closed timelike curves, such as the Kerr metric:
https://en.wikipedia.org/wiki/Kerr_metric
No such boost was reported on that wiki. I suppose that in order for someone to notice the presence of closed timelike curves within this metric, they would have to be able to somehow visualize or even graph out the spacetime geometry. Somehow, a person would have to recognize that the spacetime geometry is something akin to spherical or circular or just some shape that would allow an object to travel along some curve and then return to the same event (kind of like traveling around a globe until you eventually get back to the same point). Granted, I know that the Kerr metric describes the spacetime geometry around a spherical uncharged rotating mass, but I feel as though knowing the shape of the mass does not guarantee that the spacetime curves into the same shape.
Having said this, are there any tensors or formulas at all that would help me be able to visualize the actual geometry of a spacetime? Is there perhaps anything involving the metric tensor or covariant derivatives that would let me say "hmmm... If I propose some parameterized curve x(s) in this spacetime and traveled forward along it, then the intrinsic curvature of this spacetime would make this curve loop back on itself in a way that I would return to the initial event"?
Thanks for any assistance.
That's because the "boost" method of constructing a spacetime with CTCs is not the only way to find a spacetime with CTCs.
No, it doesn't. It describes the spacetime geometry of an uncharged rotating black hole. The Kerr metric is not spherically symmetric, and it is vacuum; the CTCs occur inside the inner horizon, which is generally believed not to be physically realistic anyway.
Some sources imply that the exterior part of the Kerr metric describes the spacetime around an ordinary rotating object (which will not be spherical--it will be oblate). However, we don't actually know that this is true, and there are plausible arguments to suggest that it can't be. But in any case, the exterior part of the Kerr metric does not contain any CTCs.
I don't know of any general way of doing this for an arbitrary spacetime. In all of the known spacetimes with CTCs, either the CTCs arise by construction, as with Misner space, or the spacetime can be described by a coordinate chart containing angular coordinates (i.e., coordinates that are periodic, going around once by ##2 \pi## takes you back to the same point) which can be shown to be timelike in some region. Kerr spacetime (and also Godel spacetime, another well known example of a spacetime with CTCs) is an example of the latter kind.
Likes space-time
So in the end, it comes down to the coordinate chart huh? Well, I think I understand, but that brings up one question. You say that the Kerr metric is an example of a metric that has a coordinate chart with periodic coordinates. Well, going based off of the wiki, I'm pretty sure the coordinate chart for the Kerr metric is:
x0 = t
x1 = r
x2 = θ
x3 = ∅
The latter two coordinates are periodic, but the first two (most importantly the temporal coordinate) are not. How then, is any curve supposed to ever loop back around to the same event? I don't think t = 2π is the same as t = 0 unlike with the angular coordinates. The same goes for r.
At most, I could see a curve returning back to the same point in space, but at a different time. Even then, I question even that possibility since you said that when you have a parameterized curve xμ(s), the derivatives (dxμ/ds) have to be positive for all s in order for the curve to be valid. This would mean that the r component of the curve could not just be a constant, which would in turn mean that r would have to change as you move along the curve.
This would mean that instead of ever returning to the exact same event, you would keep circling around the angular coordinates while continually increasing in the t and r coordinates.
space-time said:
At most, I could see a curve returning back to the same point in space, but at a different time. Even then, I question even that possibility since you [Peter] said that when you have a parameterized curve xμ(s), the derivatives (dxμ/ds) have to be positive for all s in order for the curve to be valid. ...
You are misremembering. This is what he said:
PeterDonis said:
The derivative of ##x^0(s)## with respect to s... becomes negative after s=π/2. A valid parameterization would not do that.
Meaning you can’t change direction in time, but of course you’re free to change direction in space.
Likes space-time
Not as far as the spacetime geometry is concerned. The spacetime geometry is independent of any choice of coordinates.
However, in some spacetimes with particular symmetries, such as Kerr spacetime, a well chosen coordinate chart can make certain features of the spacetime geometry easier to see. See below.
The fact that a coordinate is called ##t## does not mean it is "the temporal coordinate" everywhere. You need to actually look at the metric to see what coordinates are spacelike, timelike, or null in various regions. If you look at the Kerr metric--not just the coordinates, but the line element--you will see that there is a region inside the inner horizon where the coordinate ##\phi## is timelike. That means the worldline of an observer can point purely in the ##\phi## direction in this region. But ##\phi## is still periodic, so that means the worldline of an observer in this region can be a closed timelike curve.
space-time said:
you said that the derivatives (dxμ/ds) have to be positive for all s in order for the curve to be valid
Not for all the coordinates on all curves. I'm not sure where you think you are quoting me from, but the condition as you state it is much too strong.
For the ##\phi## coordinate, which is timelike in the region of Kerr spacetime I described, it is true that the derivative ##d \phi / d \tau## along such a timelike worldline is positive everywhere. But when you get to ##\phi = 2 \pi##, that is the same event as ##\phi = 0##, because the ##\phi## coordinate is periodic and no other coordinates are changing (##d x^\mu / d \tau = 0## for every coordinate except ##\phi##). So you have a closed timelike curve.
That makes sense I suppose. If I'm understanding correctly then, the derivatives of the spatial components of the curve are allowed to be positive, negative, or even 0. However, the derivative of the temporal component must always be positive. Is that correct?Also, even if that is correct, that still doesn't settle the issue about the temporal coordinate not being periodic. The lack of a periodic temporal coordinate would make it so that you could never return to the same point in time, even if you did return to the same point in space.
More precisely, along a future-directed timelike curve, ##d x^\mu / d \tau > 0## for any timelike coordinate ##x^\mu##, assuming the usual convention that ##\tau## increases towards the future along the curve and the timelike coordinate increases in the future direction.
However, that in itself does not tell you which coordinates, if any, are timelike. You have to look at the metric for that. Note that it is perfectly possible to have a coordinate chart where no coordinates are timelike in a region of spacetime. You certainly, as I said in my previous post just now, can't assume which coordinates are timelike or spacelike based on their names.
Likes space-time
Ok, so I previously didn't know that you could check to see if an individual coordinate was timelike/spacelike/null. I only knew how to check to see if a parameterized curve or a 4-vector was timelike/spacelike/null.
I just found this cool thread however, that seems to tell me how to check for an individual coordinate. Can you verify for me if what I am about to say is correct?:
Here is the thread by the way: https://www.physicsforums.com/threads/time-coordinate-timelike.398341/
In order to find out whether or not a coordinate is timelike/spacelike/null, you set all of the dxμ terms in the line element (except for the ones for the coordinate that you are working with) equal to 0. Then, based on what remains (and on what sign convention you're using), you can classify that coordinate as timelike/spacelike/null depending on the sign of what remains.
Using Minkowski space as an easy example:
ds2= -c2dt2 + dx2 + dy2 + dz2
If I set dx, dy, and dz equal to 0, then I am left with:
ds2= -c2dt2
This is always negative, so I suppose the t coordinate is always timelike in Minkowski space.
Note: The thread said that you set the (dxμ)2 terms equal to 0, but I assume that he really just meant the dxμ terms (even the ones that aren't squared), and he only put the squared there because a lot of metrics like Minkowski space have most of the (dxμ) terms squared.
Is my understanding correct?
Yes.
In that coordinate chart, yes. Note that the chart you are using is not the only possible coordinate chart on Minkowski spacetime. Also, you are using the convention that a negative ##ds^2## means a timelike interval, but as @DrGreg pointed out in the thread you linked to, not all of the literature uses that convention.
Yes.
Likes space-time
Related to Find CTCs in Kerr Metric: Visualizing Spacetime Geometry
1. What is the Kerr Metric?
The Kerr Metric is a mathematical model that describes the geometry of spacetime around a rotating black hole. It was developed by physicist Roy Kerr in 1963 and is an extension of the Schwarzschild Metric, which describes non-rotating black holes.
2. What are CTCs?
CTCs, or closed timelike curves, are paths in spacetime that loop back on themselves, allowing for time travel to occur. In the context of the Kerr Metric, CTCs can exist near the event horizon of a rotating black hole.
3. How can CTCs be visualized in the Kerr Metric?
CTCs can be visualized by plotting the Kerr Metric in a 3-dimensional graph, with time as one axis and the two spatial dimensions as the other two axes. CTCs will appear as closed loops in this graph, indicating the possibility of time travel.
4. What implications do CTCs have for our understanding of spacetime?
The existence of CTCs in the Kerr Metric challenges our understanding of causality and the flow of time. It suggests that time travel may be possible in certain conditions, which has significant implications for our understanding of the universe and the laws of physics.
5. How does the visualization of CTCs in the Kerr Metric aid in scientific research?
Studying the visualization of CTCs in the Kerr Metric can help scientists better understand the behavior of spacetime around rotating black holes. It can also aid in the development and testing of theories related to time travel and the nature of the universe.
