djpardi
- 5
-Find The DC voltage of the signal below created by the function generator
-Find RMS Voltage
-if the V waveform is applied across 1000 Ohm load what is the power dissipated in the load?
http://www.imagedump.com/index.cgi?pick=get&tp=515966The wave form has axis symmetry which means only cosine terms
If the signal was a unit step function only all I would need is the average value to determine the DC component. How do I get that value of a Unit Ramp Function?
Would it be an RMS value?
If so does Vrms=Vp/sqrt(2)?
Since there are several numbers of different wave forms would I get the DC component by using Fourier Series?
Fourier Series:
The area on the top side is smaller than the area on the bottom side so the DC component will be negative.
If it was a pulse, the average voltage would be, Vav=(duty cycle)(peak value)+(1-duty cycle)(Vb)
If it was a sin it would be Vrms=Vp/sqrt(2)
Im not sure what the average voltage of a ramp wave is!
Im going to guess, a0 = 1/T0* int(f(t)dt, t,-T0/2, +T0/2)
But I can't figure out how to apply it!
