Find dissipative function for the non-linear force f=-bv^n
The discussion focuses on determining the dissipative function for the non-linear force f = -bv^n in a Lagrangian framework. It is established that the dissipative function can be expressed as D = - (1/(n+1))bv^(1+n). There is clarification regarding the relationship between the force and the dissipative function, correcting a typo in the initial query. Participants confirm the correctness of the derived dissipative function. The conversation emphasizes the importance of accurately relating force and dissipative functions in nonconservative systems.
mcconnellmelany
For a nonconservative force,
What would be the dissipative function for a force f=-bvⁿ in Lagrangian
(Where v is the velocity)
[#qoute for a nonconservative force f=-bv
The dissipative function is D=-(1/2)bv² ]
##\frac{d}{dt}(\frac{\partial L}{\partial \dot x})=\frac{\partial L}{\partial x} - \frac{\partial F}{\partial \dot x}##
Since ##f=\frac{\partial D}{\partial \dot x}## so the dissipative function should be ##D=-\frac{1}{n+1}bv^{1+n}##, isn't it?
mcconnellmelany said:
Since ##f=\frac{\partial D}{\partial \ddot x}##
Do you mean ##f=\frac{\partial D}{\partial \dot x}## ?
Hmm! It was a typo.
Hmm! It was a typo.
Your answer looks right to me.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
