Find Electric Field between Two Plates with Varying Permittivity
In summary, the problem involves a parallel-plate capacitor filled with a dielectric material with varying relative permittivity. Using Gauss's law and considering the electric field to be non-uniform, the potential difference between the plates can be found by integrating the electric field across the capacitor. The final equation for the potential difference is V=E0d(10-1)/9.
rhololkeolke
We have a problem for our Electromagnetics class. It is the following
"A parallel-plat capacitor of cross-sectional area A an thickness d is filled with a dielectric material whose relative permittivity varies linearly from [tex]\epsilon_{r}=1[/tex] at one plate to [tex]\epsilon_{r}=10[/tex] at the other plate. a) Find the electric field in the capacitor b) What is the potential difference between the plates"
For a we attempted to use Gauss's law
[tex]\oint D \bullet ds = Q_{enclosed}[/tex]
We took a cylindrical surface over one of the plates.
Using the formula [tex]D = \epsilon E[/tex] we rewrote the surface integral as
[tex]\int \epsilon_{0} ds + \int \epsilon_{r0} E ds[/tex]
We did a second Gauss's law for the other plate of the capacitor. For the charge enclosed we assumed [tex]\pi r^2 \rho_s[/tex] and [tex]- \pi r^2 \rho_s[/tex] respectively.
This gave us two equations
[tex]\rho_s = \epsilon_0 E_1 + \epsilon_{r0} E_{2}[/tex]
[tex]- \rho_s = \epsilon_0 E_3 + \epsilon_{rd} E_{4}[/tex]
We assumed that [tex]E_1 = E_4[/tex]
So we solved each equation for those E and then set them equal to each other to get
[tex]\rho_s - \epsilon_{r0} E_{2} = - \rho_s - \epsilon_{rd} E_{rd}[/tex]
We know from the problem that [tex]\epsilon_{r0}[/tex] equals [tex]\epsilon_0[/tex] and we set considered [tex]E_2[/tex] to be an initial value which we called [tex]E_0[/tex].
We also detemined an equation relation [tex]\epsilon_r[/tex] to x.
[tex]\epsilon_r = 1 + \frac {9x} {d}[/tex]
Plugging this in and solving for [tex]E_{rd}[/tex] gave us the following equation
[tex]E_{rd} = \frac {\epsilon_0 E_0 - 2 \rho_s} {(1 + \frac {9x} {d}) \epsilon_0}[/tex]
Our question is whether our approach is right. If it isn't we would like some direction to head in. For the second part of the problem we were going to use the relation
[tex]E = - \frac {dV} {dx} [/tex] to find the potential.
Any help is appreciated.
Thank you.Your approach is on the right track, but you need to take into account the fact that the electric field is not uniform throughout the capacitor. The electric field will be stronger near the plate with the higher relative permittivity and weaker near the plate with the lower relative permittivity. To solve the problem, we can use a method of integration. Start by integrating the electric field across the capacitor. We have E=E0(1+9x/d) where E0 is the initial electric field at x=0. Integrating this equation from 0 to d will give us the total potential difference between the two plates. We can then apply the equation V=Ed to find the potential difference between the two plates. The final answer is: the potential difference between the plates is V=E0d(10-1)/9.
Related to Find Electric Field between Two Plates with Varying Permittivity
1. What is the equation for finding the electric field between two plates with varying permittivity?
The equation for finding the electric field between two plates with varying permittivity is E = (Q/εA), where E is the electric field, Q is the charge on one of the plates, ε is the permittivity of the material between the plates, and A is the area of the plates.
2. How does varying permittivity affect the electric field between two plates?
Varying permittivity affects the electric field between two plates by changing the strength of the electric field. A higher permittivity will result in a stronger electric field, while a lower permittivity will result in a weaker electric field.
3. What is permittivity and how does it relate to the electric field?
Permittivity, denoted by the symbol ε, is a measure of a material's ability to store an electric field. It relates to the electric field by determining the strength of the electric field between two charged objects or plates.
4. Can the electric field between two plates with varying permittivity be negative?
Yes, the electric field between two plates with varying permittivity can be negative. This occurs when the charges on the plates are of opposite signs and the electric field is directed towards the negatively charged plate.
5. How can the electric field between two plates with varying permittivity be used in practical applications?
The electric field between two plates with varying permittivity can be used in various practical applications, such as in capacitors, where it is used to store and control the flow of electric charge. It is also used in electronics, such as in the design of computer memory and display screens.
