Find electric potential at a center of charged rod
In summary, you need to find the electric potential at a point on the rod if the referent point is at infinity.
gruba
206
Find electric potential at a center of charged rod with charge 'Q' and length '2a' if referent point is at infinity.
Electric potential of a point charge: V=kQ/r
Electric potential via electric field: integral (Edl)
I used relation for potential of point charge:
V=kQ/(1/r_A-1/r_B), where r_A is a distance between charge and point, and r_B is the distance of infinity. From there, I think that r_A=a because that is the maximum distance between point and charge (point lies on the rod). This gives
V=kQ/a
Is it right that if we calculate potential of this rod in a given point, where referent point is at infinity, we can look at the rod as a point charge?
Could someone show the steps if this isn't correct?
Thanks for replies.
V=kQ/a
Thanks for replies.
Is this the complete problem statement as it was given to you?
It seems to me, that unless you have some finite (rather than infinitesimal) radius for the rod, the potential at any point on the rod will be infinitely large.
The rod is a line of length '2a'. There are no calculations (values).
So, it doesn't have a radius of R, or diameter of D, for instance?
No, it is a straight line (finite rod).
So, it has no thickness?
No.
gruba said:
No.
or .. is that, Yes, it has no thickness?
It has no thickness.
What you are trying to do here is not entirely clear.
If this is an assigned problem, then please state the entire problem. If this is a problem of your own creation, then there is a flaw in it.
Your method will not work.If you want to find the electric potential (due to the rod) at a point sufficiently far from the finite rod, then, yes, you can treat the rod as a point charge. However, it appears that you want to find the electric potential at a point directly on the rod, namely at its center. You will be integrating 1/r as r → 0 . That's a problem.
Okay, I thought we can look at the rod as point charge if finding potential ON the rod (center). What am I doing wrong? Can you show your calculations?
I hate to be repetitious, but ...
Please answer.
Please answer.
I am sorry, but I don't understand what is unclear about the problem. Finite straight rod of length '2a' is charged with 'Q'. Find electric potential at the center of a rod (point lies on a rod) if referent point is at infinity.
Is this actually a legitimate exercise from a book, or given to you by an instructor? Is it the COMPLETE statement of the problem?
Yes, it is complete statement. I had this problem in my exam paper.
Then the electric potential at any point directly on the rod is ± ∞, with the sign corresponding to the sign of charge Q. This is relative to the electric potential being zero at an infinite distance from the rod.
Do you know how to find either the electric field or electric potential by integration ?
I know to use superposition method when point is not directly on a charge. I don't get how did get potential on center of a rod is equal to infinity? Can you show?
Well, that's the problem. The center of the rod is a point directly on a charge and in this case that can't be overcome.
Do you have theoretical explanation?
I have calculated the new result for potential at the center of rod:
V=Q*ln(a)/(4pie_0*a)
I used superposition. If one half of a rod has length 'a', then from point at center to 'a' is infitinely many 'dQ' elements which needs to be summed. The same process goes with the other half of a rod (muliplication by 2).
V=2*k*integral(0-a)(Q'dl/r)=Q*ln(a)/(4pie_0*a)
Could you check this?
I used superposition. If one half of a rod has length 'a', then from point at center to 'a' is infinitely many 'dQ' elements which needs to be summed. The same process goes with the other half of a rod (multiplication by 2).
(The overall solution is more complicated than this), but the main problem is in evaluating that integral which does show how the potential behaves near the rod.
##\displaystyle\ \int_{0}^{a}\frac{Q}{r}dr=Q\left(\ln(r) \right|_0^a \ ##
##\ \ln(0)\ ## is undefined.
V=(Q/(8pi*e_0*a))*ln2
Is this correct?
Is this correct?
What are you doing to eliminate ln(0) ?
Instead of using limits of integration (0-a), I used (2a-4a). That is because length of the rod is '2a'
Then you're finding the potential at some point along the rod that is a distance of ##\ a \ ## away from the near end of the rod. That's hardly at the center.
Do you know the solution?
Sure. But it goes to ∞ as the point gets close to the rod.
Find the potential a distance, b, from the rod at the rod's center. In other words, at a location a distance, b, in a direction perpendicular to the rod.
##\displaystyle\ V(b)=2\frac{Q}{2a}\int_{0}^{a}\frac{1}{\sqrt{x^2+b^2\,}}dx \ .##
Likes gruba
Could you show your full calculations for this problem if you have done it?
Related to Find electric potential at a center of charged rod
1. How is electric potential defined?
The electric potential at a point is defined as the amount of work required to bring a unit positive charge from infinity to that point, divided by the magnitude of the charge.
2. What is the formula for calculating electric potential at a point?
The formula for calculating electric potential at a point is V = kQ/r, where V is the electric potential, k is the Coulomb's constant, Q is the charge, and r is the distance from the point to the charge.
3. How is electric potential different from electric field?
Electric potential is a scalar quantity that measures the potential energy of a charge at a point, while electric field is a vector quantity that measures the force exerted on a charge at a point.
4. Can electric potential be negative?
Yes, electric potential can be negative. A negative electric potential indicates that the work required to bring a unit positive charge from infinity to that point is negative, meaning that the charge is moving in the opposite direction of the electric field.
5. How does the electric potential change along a charged rod?
The electric potential decreases as the distance from the center of the charged rod increases. This is because the electric field of the rod decreases with distance, resulting in a lower potential at points farther away from the rod's center.
