Find Energy Stored in Two Parallel Springs
In summary, the problem involves two springs, one inside the other, and a block of mass M compressing them a distance d1 and d2. The initial velocity of the block can be solved for by finding the area under the force vs distance curve, which can be done by integrating the equations for each spring separately.
c7ng23
There are two springs, one long spring of constant k1 and it is inside a smaller spring of constant k2. Both springs follow Hooke's Law. A box of mass M moves without friction and compresses spring 1 a distance d1 where it hits spring 2. Spring 1 and 2 then compress further distance d2. Solve for the initial velocity of the block.
F = -kx
U = 1/2 mv^2 = 1/2 kx^2
I was able to get the solution from the following: (1/2)M v^2 = 1/2 k1 d2^2 + 1/2 k2 (d2-d1)^2 and solving for v. I also thought I could get the solution from finding the area under a force vs distance curve but I was unsuccessful. In this attempt I found the area under the small triangle formed by k1 slope, the area of the larger triangle formed by k1+k2 and the little rectangle beneath.
The equation was: 1/2 k1 d1^2 + 1/2 [(k1+k2)d2 - k1d1]*(d2-d1) + k1d1d2
I attached a picture of the initial scenario and graph. Any help is greatly appreciated, thanks!
It says a further distance d2 which you have interpreted as d2-d1.
This may be the problem. Try taking it d1+d2 on graph instead of d2 and check for the answer.
I wanted to update- I found the area under the curve by integrating and it matched the answer as if we considered the energy stored in the compression of the springs separately:
[tex]\int ^{d1}_{0}k_{1}x +\int ^{d2}_{d1} (k_{1}+k_{2})x +k_{1}d_1[/tex]
[tex]\ \frac{1}{2} k_{1}d_{1}^2 + \frac{1}{2}(k_1+k_2)(d_2-d_1)^2 +k_1d_1(d_2-d_1)[/tex]
[tex]\ \frac{1}{2}k_1d_1^2 + \frac{1}{2}(k_1d_2^2 +k_1d_1^2-2k_1d_1d_2 +k_2d_2^2+k_2d_1^2 - 2k_2d_1d_2) +k_1d_1d_2 - k_1d_1^2 [/tex]
[tex]\ \frac{1}{2}k_1d_2^2 + \frac{1}{2}k_2d_2^2 + \frac{1}{2}k_2d_1^2 - k_2d_1d_2 [/tex]
And this is the same as the two springs separately:
[tex]\ \frac{1}{2}k_1d_2^2 + \frac{1}{2}k_2(d_2-d_1)^2 [/tex]
FAQ: Find Energy Stored in Two Parallel Springs
What is the formula for finding the energy stored in two parallel springs?
The formula for finding the energy stored in two parallel springs is E = 1/2(k1x1^2 + k2x2^2), where k1 and k2 represent the spring constants and x1 and x2 represent the displacements of each spring.
How do you calculate the spring constants for two parallel springs?
The spring constants for two parallel springs can be calculated by taking the inverse of the sum of the reciprocals of each spring's individual spring constant. In equation form, it would be 1/k = 1/k1 + 1/k2, where k is the combined spring constant.
What units are used for the spring constants and displacements in the energy formula?
The units for the spring constants in the energy formula are typically in units of force per unit of length, such as N/m or lbs/in. The displacements are typically measured in meters or inches.
Can the energy stored in two parallel springs be negative?
Yes, the energy stored in two parallel springs can be negative if the displacements of the springs are in opposite directions. This indicates that the springs are exerting a restorative force in opposite directions, resulting in a decrease in the stored energy.
What factors can affect the energy stored in two parallel springs?
The energy stored in two parallel springs can be affected by the spring constants, displacements, and any external forces acting on the springs. The material and properties of the springs can also impact the amount of stored energy.
