MHB *find eq of perpendicular line so that the area of the triangle is 8
To find the equation of a perpendicular line that encloses a triangle with an area of 8 alongside the line y=4x-2, the base and height of the triangle must be calculated. The base is expressed as B=(4x-2)+2+(1/4)x, simplifying to B=(17/4)h, where h is the height. The area formula, Area=(1/2)BH, leads to the equation (b+2)(4b+2)/30=8 for calculating b. The intersection of the two line equations is used to determine the height, H=(4b+2)/15. Ultimately, there are two possible triangles that satisfy the conditions of the problem.
karush
MHB
for the line y=4x-2 there is one perpendicular line of which will enclose a triangle on the lines and the values of the y-axis whose area is 8. What is the equation of this line?
Well, I chose the x value to be the height of the triangle and that would make the base $$B=(4x-2)+2+\frac{1}{4}x$$ or just $B=\frac{17}{4}h$ if $h=$ the $x$ value.
just seeing if I am going the right direction with this seem more complicated than is should be. got to be a slam dunk method...
I got a weird answer for $h=\frac{8}{\sqrt{17}}$ and $b=2\sqrt{17}$
Mathematics news on Phys.org
The area of a triangle is given from the formula $$\text{ Area }=\frac{1}{2} B H$$
You will find the part of the basis $B$ that is over the $x$-axis, by setting at the equation $y=\frac{x}{4}+b$, $x=0$. So, it is equal to $b$.
The part of $B$ under the $x$-axis is equal to $2$.
Therefore, $B=b+2$.
You will find the height $H$ by finding the intersection between the two line equations:
$$\frac{x}{4}+b=4x-2 \Rightarrow x=\frac{4b+2}{15}$$
Therefore, $H=\frac{4b+2}{15}$.
So, to calculate $b$ we have to solve the following:
$$B \cdot H=8 \Rightarrow \frac{b+2}{2} \frac{4b+2}{15}=8$$
Karush,
Actually, there are 2 such triangles.
ok I posted this problem also on Linkedin since it had over 1000 views
but there was an image with this problem which was from a SAT pdf
but I couldn't find it but apparently the image is not necessary to solve it
Anyway
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
