MHB Find Equation of Plane Perpendicular to Line $l(t)$
  • Thread starter Thread starter evinda
    Plane
To find the equation of a plane perpendicular to the line \( l(t) = (-1,-2,3)t + (0,7,1) \) and passing through the point \( (2,4,-1) \), the direction vector of the line, \( (-1,-2,3) \), serves as the normal vector for the plane. The general equation of the plane can be expressed as \( -x - 2y + 3z + D = 0 \). Substituting the coordinates of the point \( (2,4,-1) \) into this equation allows for the determination of \( D \). The final equation of the plane is derived as \( -x - 2y + 3z = 14 \). This method effectively utilizes the properties of perpendicularity and the standard form of a plane equation.
evinda
MHB
Hello! (Wave)
If we want to find the equation of the plane that is perpendicular to the line $l(t)=(-1,-2,3)t+(0,7,1)$ and passes through $(2,4,-1)$.
If (x,y,z) is a point of the line then it is of the form (-t,-2t+7,3t+1).
We get that $t=-x=\frac{7-y}{2}=\frac{z-1}{3} \Rightarrow -2x=7-y=\frac{2z-2}{3} \Rightarrow -6x=21-3y=2z-2 $
Can we find in that way the equation of the plane?
Also, is the following way also right to find the desired equation?
For $t=1$ , $a=(-1,5,4)$ where $a \in l(t)$.
Let $(x,y,z)$ be a point of the plane.
Then $(x-2,y-4,z+1)$ belongs to the plane.
Since $l(t)$ is perpendicular to the plane, $a$ is also perpendicular to the plane and since $(x,y,z)$ is a point of the plane, $a$ is perpendicular to $(x,y,z)$. So $a \cdot (x,y,z)=0 \Rightarrow -x+5y+4z=14$
Why?
If you write $a \in l(t)$, it means that $a$ is a point, and a point cannot be perpendicular to anything.
Again, points can't be perpendicular.
It is known that the equation of a plane is $Ax+By+Cz+D=0$ where $(A,B,C)$ are the coordinates of a vector perpendicular to the plane. In your case, this vector is $(−1,−2,3)$. It is left to substitute the coordinates of a point on the plane into the equation to find $D$.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
  • · Replies 17 ·
