Find equilibrium points given 2 differential equations
In summary, the first equation tells you that there is an equilibrium point where y=0. The second equation tells you that if y=0, x=-4,1,3...
reality99
Given a system of differential equations and asked to find the equilibrium points and classify them.
Equation 1 ... dx/dt=y(13-x^2-y^2 )
Equation 2 ... dy/dt=12-x(13-x^2-y^2 )
I know the solution comes when the derivative is 0, so I set both equations to 0 and tried to solve from there. For equation 1, I get one of the solutions as y=0, x=N (assuming x+y=N). I also get x=+/- sqrt(13-y^2), y=sqrt(13/2). Is this correct for the first equation? I'm having trouble understand how to interpret these...
For equation 2 I am more confused since setting it to 0 ends up having a cubic term equal to a constant. My professor said it's similar to the first one and gave me something about if xyA=0 for the first equation then y(12-xA)=0 for equation 2... I don't really understand what this means/how to apply it. I can get the second equation to (x-1)(x-3)(x+4)+(x(y^2))=0 so if y=0 (which I believe is how the solution is supposed to work out, I just don't know why) then x=-4,1,3... Any help or explanation is greatly appreciated!
The first equation tells you 0=y*(13-x^2-y^2). That means either y=0 or (13-x^2-y^2)=0. If 13-x^2-y^2=0 can you have an equilibrium point? Look at the second equation.
So the system is inconsistent?
No. You have just ruled out the possibility that (13-x^2-y^2)=0 at an equilibrium point. There was another possibility suggested by the first equation, wasn't there?
This gets more confusing the more I think about it... From the condition (13-x^2-y^2)=0, I got x=+/- sqrt(13-y^2), then plugging x back into (13-x^2-y^2)=0 means that y=0 and x=sqrt(13)?? Or am I going in circles?
(13-x^2-y^2)=0 doesn't give you an equilibrium point. The second equation told you that. So forget about it. The first equation also works if y=0. Pursue that possibility.
Ok, I don't know what I was doing before but I think I understand it now. Maybe.
[strike]If y=0, then x=12 or +/-sqrt(13)---> (12,0) and (sqrt(13),0)
another possibility if y=/=0 would be (x, +/-sqrt(13-x^2)) right?[/strike]
EDIT: (because I made a stupid mistake above)
y=0, x=1,3,-4
when y=0 the second equation is 12-x(13-y^2-x^2)=0 which is 12-x(13-x^2)=x^3-13x+12=(x-1)(x-3)(x+4) [I wrote it down wrong the first time I did it above, (12-x)(13-x^2)=/=12-x(13-x^2)...duh]
That's it.
Thanks so much for the help! I really appreciate it!
FAQ: Find equilibrium points given 2 differential equations
What are equilibrium points in a differential equation?
Equilibrium points in a differential equation are the values at which the rate of change of the dependent variable is equal to zero. In other words, they are the points where the system is balanced and remains at a constant state.
How do you find equilibrium points in a differential equation?
To find equilibrium points in a differential equation, you need to set both equations equal to zero and solve for the variables. This will give you the values of the variables at which the system is in equilibrium.
What is the significance of equilibrium points in a differential equation?
Equilibrium points are important in differential equations as they represent stable states of a system. They can help us understand the behavior of the system and make predictions about its future state.
Can a system have more than one equilibrium point?
Yes, a system can have multiple equilibrium points. This means that there are multiple values at which the system can remain in a constant state. These points can represent different stable states of the system.
How does the stability of an equilibrium point affect the behavior of a system?
The stability of an equilibrium point determines whether the system will return to that point after a small disturbance or move away from it. A stable equilibrium point will result in a system returning to it, while an unstable equilibrium point will result in the system moving away from it.
