MHB Find Exact Distance: (2,-2) to (5,2) - Help!
  • Thread starter Thread starter OMGMathPLS
The discussion focuses on finding the exact distance between the points (2, -2) and (5, 2) using the distance formula. Initially, there was confusion about plugging values into the formula, leading to an incorrect calculation. After realizing the mistake, the correct application of the formula yielded a distance of 5. Participants shared that it is common to struggle with variable placement in formulas and emphasized that practice is key to overcoming these challenges. Understanding each parameter in the formula is crucial for accurate calculations.
OMGMathPLS
Find exact distance between two points. (2, -2) (5, 2)
I plug in the distance formula but I get
sq rt (5-2)^2+ (2-(1)^2
and I get 9 on both sides so that's sq rt 18 = 4.24
but the book says it's 5
so i don't know what I'm doing wrong. Help please.
- - - Updated - - -
Wait, I see i plugged it in the wrong spot. Oh thank God it was that simple. Oh thank you Jesus.
- - - Updated - - -
Ok, so my new question is is it normal to have a hard time plugging into the spots. I feel dyslexic as I am doing this. is there a trick to remember it?
Mathematics news on Phys.org
You want to use:
$$d=\sqrt{(5-2)^2+(2-(-2))^2}=\sqrt{3^2+4^2}=\sqrt{25}=5$$
You see, the distance formula states that given two points $\left(x_1,y_1\right)$ and $\left(x_2,y_2\right)$. then the distance $d$ between these points is given by:
$$d=\sqrt{\left(x_2-x_1\right)^2+\left(y_2-y_1\right)^2}$$
MarkFL said:
You want to use:
Thanks MarkFl
I want to ask you, how do you keep from getting the variables confused amongst each other and how many times do you recheck to make sure it's correct? How old were you when you first learned this level of math?
It just takes practice...you are not alone in finding it a challenge at times to know which of the given data values goes into which place in a formula. :D
I have had lots and lots of practice over the last 23 years. I was 27 when I really began studying mathematics.
Just make certain you understand what each parameter in a given formula represents. ;)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
