Find f(a+b): $f(x)=\dfrac {2^x+2^{-x}}{2^x-2^{-x}}$
  • MHB
  • Thread starter Albert1
In summary, to find the value of f(a+b), you can substitute the value of a+b into the equation for x. This can be simplified to 2coth(x), making it easier to find the value of f(a+b). If a and b are variables, you can use algebraic manipulation to solve for f(a+b). A calculator can also be used to find the value of f(a+b) using the simplified equation. Additionally, the equation for f(x) has practical applications in fields such as physics, engineering, finance, and economics. It can be used to model exponential growth, calculate rates of change, and determine interest and growth rates.
Albert1
1,221
$f(x)=\dfrac {2^x+2^{-x}}{2^x-2^{-x}},x\in R, x\neq 0$
$if$
$(1)f(a)=\dfrac{17}{15}$
$and$
$(2)f(b)=-\dfrac{65}{63}$
$find :f(a+b)$
Mathematics news on Phys.org
$if$
$and$
$find :f(a+b)$
we have $f(a)=\frac {2^a+2^{-a}}{2^a-2^{-a}} = \frac{2^{2a}+1}{2^{2a}-1} = 1 + \frac{2}{2^{2a}-1} = 1 + \frac{2}{15}$
hence $2^{2a}-1 = 15$ or $a = 2$
we have $f(b)=\frac {2^b+2^{-b}}{2^b-2^{-b}} = \frac{1 + 2^{-2b}}{1 - 2^{-2b}} = \frac{-65}{63}$
or
$\frac{1 + 2^{-2b}}{2^{-2b}-1} = \frac{-65}{63}$ giving -2b = 6(same method as for a) or b = -3
so a + b = -1
so $f(a+b) = \frac{2^{-1} + 2^1}{2^{-1} - 2^1} = \frac{-5}{3}$
$if$
$and$
$find :f(a+b)$
$f(a)=\dfrac{17}{15}$
$\dfrac {2^a+2^{-a}}{2^a-2^{-a}}=\dfrac{17}{15}$
$\dfrac {2^{2a}+1}{2^{2a}-1}=\dfrac{17}{15}$
$17(2^{2a}-1)=15(2^{2a}+1)$
$17\cdot2^{2a}-17=15\cdot2^2a+15$
$2\cdot2^{2a}=32$
$2^{2a}=16$
$2a=4$
$a=2$
$f(b)=-\dfrac{65}{63}$
$\dfrac {2^b+2^{-b}}{2^b-2^{-b}}=-\dfrac{65}{63}$
$\dfrac {2^{2b}+1}{2^{2b}-1}=-\dfrac{65}{63}$
$65(2^{2b}-1)=-63(2^{2b}+1)$
$65\cdot2^{2b}-65=-63\cdot2^2b-63$
$128\cdot2^{2b}=2$
$2^{2b}=\dfrac{2}{128}$
$2^{2b}=\dfrac{1}{64}$
$2^{2b}=2^{-6}$
$2b=-6$
$b=-3$
$f(a+b)=f(2-3)$
$f(a+b)=f(-1)$
$f(a+b)=\dfrac {2^{-1}+2^{1}}{2^{-1}-2^{1}}$
$f(a+b)=\dfrac {\frac{5}{2}}{-\frac{3}{2}}$
$f(a+b)=-\dfrac {5}{3}$
FAQ: Find f(a+b): $f(x)=\dfrac {2^x+2^{-x}}{2^x-2^{-x}}$
How do I find the value of f(a+b)?
The value of f(a+b) can be found by substituting the value of a+b into the equation for x. This will give you the numerical value of f(a+b).
Can I simplify the equation for f(x)?
Yes, the equation for f(x) can be simplified to 2coth(x), where coth(x) is the hyperbolic cotangent function. This simplification can make it easier to find the value of f(a+b).
How do I solve for f(a+b) if a and b are variables?
If a and b are variables, you can use algebraic manipulation to find the value of f(a+b). First, substitute a and b into the equation for x. Then, use algebraic operations such as distribution and simplification to solve for f(a+b).
Can I use a calculator to find the value of f(a+b)?
Yes, you can use a calculator to find the value of f(a+b). Most scientific calculators have functions for cotangent and hyperbolic cotangent, which can be used to find the value of f(a+b) using the simplified equation.
How can I use the equation for f(x) in real-world applications?
The equation for f(x) can be used in many real-world applications, such as in physics and engineering. It can be used to model exponential growth and decay, as well as to calculate rates of change. It can also be used in finance and economics to calculate interest rates and growth rates.
