Find Final Kinetic Energy of a particle subject to two forces
maguss182
The force of gravity (-mg) in the k direction and the non conservative force (-b)i-(b)j-(b)k act on a particle that starts off at speed V(int) from the origin to a point (1,1,0), while moving first in the x direction than in the y direction. Find the final kinetic energy of the particle.
DeltaT-DeltaU=Wnc T=1/2mv^2 U=-mg,
I'm having trouble putting the rest of the equations together, I believe I need the different from (0,0,0) to (1,0,0) and then (1,0,0) to (1,1,0) right? Then solve for x direction and y direction. What would I use for Wnc tho? I'm very confused.
nm i got it
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
