Find Flux Through Black Hole: Metric g & Gauge Field A
To find the flux through a sphere surrounding a black hole using the black hole metric g_{\mu\nu} and gauge field A_\mu, one must compute the Hodge star of the field strength F, expressed as (\star F)_{\alpha\beta\gamma} = F^{\mu\nu} \sqrt{-g}\epsilon_{\mu\nu\alpha\beta\gamma} in five-dimensional AdS space. To determine the total charge, integrate the current J = d*F over a volume, using the covariant derivative of the field tensor. The integration involves pulling back the n-form K to the n-surface and performing an ordinary n-dimensional integral. For a closed (d-2)-surface containing the charge, integrate *F over a 3-sphere in spherical coordinates around the black hole. This method effectively calculates the electric charge sourced by the Maxwell field F.
praharmitra
Given a black hole metric g_{\mu\nu} and gauge field A_\mu, how do I find the flux through a sphere of a black hole.
In simpler terms how do you find \star F (the hodge star, I believe) using the metric ??
Well, I found out that
(I am in five dimensional AdS space)
How do I integrate this now to find the total charge? Please help
In tensor terms, use the covariant derivative of the field tensor to get the current and integrate the time component over a volume.
In this case J = d*F ( 4-form ?) which I presume is integrable.
It seems like you're just asking how to integrate forms.
To integrate a n-form K over an n-surface \Sigma, first you must find the pullback of K to \Sigma; then you just do an ordinary n-dimensional integral. Suppose x^a are the coordinates on your manifold. Then K can be written
K = \frac{1}{n!} K_{a_1 \ldots a_n} \; dx^{a_1} \wedge \ldots \wedge dx^{a_n}
Now, if y^b are the coordinates of the n-submanifold \Sigma, then
\int_\Sigma K = \underbrace{\idotsint}_n K_{a_1 \ldots a_n} \; \frac{\partial x^{a_1}}{\partial y^1} \ldots \frac{\partial x^{a_n}}{\partial y^n} \; dy^{1} \ldots dy^{n}
To find the electric charge that sources some Maxwell field F, you integrate *F over a closed (d-2)-surface that contains the charge. In your case, you are in 5 dimensions, and you probably have spherical symmetry. So use spherical coordinates, and integrate over a 3-sphere centered on the black hole (set R and T to constants).
In an inertial frame of reference (IFR), there are two fixed points, A and B, which share an entangled state $$ \frac{1}{\sqrt{2}}(|0>_A|1>_B+|1>_A|0>_B) $$ At point A, a measurement is made. The state then collapses to $$ |a>_A|b>_B, \{a,b\}=\{0,1\} $$ We assume that A has the state ##|a>_A## and B has ##|b>_B## simultaneously, i.e., when their synchronized clocks both read time T However, in other inertial frames, due to the relativity of simultaneity, the moment when B has ##|b>_B##...
  • · Replies 44 ·
  • · Replies 62 ·
  • · Replies 67 ·
  • · Replies 20 ·
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 24 ·
