MHB Find $\frac{a}{b}$ in the Circle of Balls
  • Thread starter Thread starter maxkor
    Balls Circle
The discussion focuses on finding the ratio $\frac{a}{b}$ in a geometric problem involving circles. Users are encouraged to share their progress to receive targeted help. Key equations are established, including $c = \frac{1}{2}a = \frac{1}{2}b - r$ and $b = 2c + 2r$. The connection between $a$, $b$, and $r$ is derived using Pythagorean theorem applications in specific triangles. The final answer proposed for the ratio $\frac{a}{b}$ is confirmed to be $\frac{\sqrt{2}}{2}$.
maxkor
Mathematics news on Phys.org
maxkor said:
How find $\frac{a}{b}$
Hi maxkor! (Smile)
We ask that our users show their progress (work thus far or thoughts on how to begin) when posting questions. This way our helpers can see where you are stuck or may be going astray and will be able to post the best help possible without potentially making a suggestion which you have already tried, which would waste your time and that of the helper.
Can you post what you have done so far?
Let 1/2b radius of the big circle, let r radius of the smaller circle
Let $c=1/2a=1/2b−r,
b=2c+2r,
a=2c.$
So $\frac{a}{b}=\frac{2c}{2c+2r}=\frac{c}{c+r}$
Small circles respectively tangential to the large circles so
$z=c+2r,t=a−r=2c−r$
Is this right?
Use Pythagoras in the triangles $CXY$, $DXY$ (where $Y$ is the centre of one of the footballs) to find two expressions for $XY^2$ in terms of $a$, $b$ and $r$. Putting those expressions equal to each other will give you an equation connecting $a$, $b$ and $r$.
You already know that $r = \frac12(b-a)$ (from your equation $c = \frac12a = \frac12b-r$). Substitute that value of $r$ into your equation, and it will give you the connection between $a$ and $b$.
Is $\frac{a}{b}=\frac{\sqrt{2}}{2}$ correct answer?
Yes! (Happy)
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
  • · Replies 22 ·
