Find g(x)/h(y) for a given F(x,y)
  • Thread starter Thread starter songoku
The discussion focuses on finding the ratio g(x)/h(y) for the function F(x,y) = f(2x^2 + 5y^2) using its partial derivatives. The participants derive the expressions for the partial derivatives and set up the relationship between them, leading to the equation 10y ∂F/∂x - 4x ∂F/∂y = 0. There is a consensus that while the ratio g(x) = 4x and h(y) = 10y satisfies the equation, it does not prove that this ratio is valid for all possible functions g and h. The correct approach is emphasized as starting from the algebraic relationship h(y)F_x + g(x)F_y = 0, leading to g(x)/h(y) = -F_x/F_y. The discussion concludes with an acknowledgment of the correct method to solve the problem.
songoku
Given that ##F(x,y)=f(2x^2 +5y^2)## and satisfies ##h(y) \frac{\partial F}{\partial x}+g(x) \frac{\partial F}{\partial y}=0##, find ##\frac{g(x)}{h(y)}##
Partial derivative
$$F(x,y)=f(2x^2+5y^2)$$
$$\frac{\partial F}{\partial x}=f'(2x^2+5y^2) . (4x)$$
$$\frac{\partial F}{\partial y}=f'(2x^2+5y^2).(10y)$$
##f'(2x^2+5y^2)=\frac{\partial F}{\partial x} . \frac{1}{4x} = \frac{\partial F}{\partial y} . \frac{1}{10y}##
So
$$\frac{\partial F}{\partial x} . \frac{1}{4x} = \frac{\partial F}{\partial y} . \frac{1}{10y}$$
$$\frac{\partial F}{\partial x} . 10y=\frac{\partial F}{\partial y} . 4x$$
$$10y . \frac{\partial F}{\partial x}-4x . \frac{\partial F}{\partial y}=0$$
Then
$$\frac{g(x)}{h(y)}=-\frac{4x}{10y}$$
But the answer is ##\frac{4x}{10y}##. Where is my mistake?
Thanks
I agree with your minus result.
I agree with the minus sign. I disagree with your approach. You demonstrated that ##h(y)=10y## and ##g(x)=4x## happen to satisfy the equation, and then computed the ratio of them. But that doesn't really prove that ratio works for any choice of ##g## and##h## that satisfy the equation (of which there are many)
I think what they wanted you to do is simply algebra
##h(y)F_x+g(x)F_y=0##
##g(x)F_y=-h(y)F_x##
##g(x)/h(y)=-F_x/F_y##
Likes PeroK and songoku
Ah I see it is possible to start from there. I thought I had to start from partial derivative and tried to rearrange the equation to fit the question.
Thank you very much anuttarasammyak and Office_Shredder
Question: A clock's minute hand has length 4 and its hour hand has length 3. What is the distance between the tips at the moment when it is increasing most rapidly?(Putnam Exam Question) Answer: Making assumption that both the hands moves at constant angular velocities, the answer is ## \sqrt{7} .## But don't you think this assumption is somewhat doubtful and wrong?
  • · Replies 18 ·
