Find half-life from an atomic ratio?
In summary, half-life is the time it takes for half of the atoms in a sample of a radioactive substance to decay. It can be measured by observing the decrease in the number of atoms, and can be calculated from an atomic ratio using a specific formula. Half-life varies for different radioactive substances and is an indication of an element's stability, with shorter half-lives indicating less stability and quicker decay.
doanta
An equilibrium ore mixture has an atomic ratio for [tex]\frac{U-235}{Pa-231} = 3.04x10^{6}[/tex]
Find the half-life of U-235 from the data. The known half-life for Pa-231 is [tex]3.28x10^{4}[/tex] years
For secular equilibrium
[tex]\frac{\lambda_{2} N_{2}}{\lambda_{1} N_{1}} = 1
[/tex]
[tex]\lambda = \frac{Ln(2)}{Half-Life}[/tex]
[tex]\lambda_{Pa-231} = \frac{Ln(2)}{3.28x10^{4}} = 2.113x10^{-5}y^{-1}[/tex]
[tex]\frac{2.113x10^{-5}y^{-1}}{\lambda_{1}} = 3.04x10^{6}[/tex]
[tex]\lambda_{1} = 6.951x10^{-12}[/tex]
[tex]T_{1/2_{U}} = \frac{Ln(2)}{6.951x10^{-12}}[/tex]
[tex]T_{1/2_{U}} = 9.97x10^{10}yrs[/tex]
Am I taking the right approach? I know the half life of U-235 is only [tex]7.04x10^{8}[/tex] and my answer is pretty far off.
Your approach is correct, but there seems to be an error in your calculation. When you calculated the value for \lambda_{Pa-231}, you used the half-life of 3.28x10^{4} years, but then in the next step, you used the value of 2.113x10^{-5}y^{-1} as \lambda_{Pa-231}. This value is actually \lambda_{U-235}.
The correct calculation would be:
\frac{\lambda_{U-235} N_{U-235}}{\lambda_{Pa-231} N_{Pa-231}} = 1
\frac{2.113x10^{-5}y^{-1} N_{U-235}}{2.113x10^{-5}y^{-1} N_{Pa-231}} = 1
N_{U-235} = 3.04x10^{6} N_{Pa-231}
Using the known half-life for Pa-231, \lambda_{Pa-231} = \frac{Ln(2)}{3.28x10^{4}} = 2.113x10^{-5}y^{-1}, we can solve for N_{Pa-231}:
N_{Pa-231} = \frac{3.04x10^{6}}{2.113x10^{-5}} = 1.44x10^{11}
Now, we can use the value for N_{Pa-231} to solve for the half-life of U-235:
\lambda_{U-235} = \frac{Ln(2)}{T_{1/2_{U}}}
2.113x10^{-5}y^{-1} = \frac{Ln(2)}{T_{1/2_{U}}}
T_{1/2_{U}} = \frac{Ln(2)}{2.113x10^{-5}y^{-1}}
T_{1/2_{U}} = 3.28x10^{4} years
This is the same value as the known half-life for Pa-231, so it seems that there may have been an error in the given data or in the calculation of the atomic ratio.
In summary, your approach is correct, but there was a small error in the calculation. Keep in mind to always double check your values and units to ensure accuracy in
FAQ: Find half-life from an atomic ratio?
What is half-life?
Half-life is the amount of time it takes for half of the atoms in a sample of a radioactive substance to decay into a different element.
How is half-life measured?
Half-life can be measured by observing how long it takes for the number of atoms in a radioactive substance to decrease by half.
Can half-life be calculated from an atomic ratio?
Yes, half-life can be calculated from an atomic ratio by using the formula t1/2 = ln(2) / λ, where λ is the decay constant and can be determined from the atomic ratio.
Is half-life a constant value for all radioactive substances?
No, half-life varies depending on the specific radioactive substance. Each substance has its own unique half-life.
How does half-life relate to the stability of an element?
Half-life is a measure of the stability of an element. Elements with shorter half-lives are more unstable and will decay more quickly, while elements with longer half-lives are more stable and will take longer to decay.
