Find how far a proton travels between capacitor plates
In summary, the electric potential of a capacitor is given by V=Ex where E is the electric field and x is the distance from the negatively charged plate.
r-swald
A proton is fired with an initial speed (V_0) of 100,000 m/s from the midpoint of a capacitor toward the positively charged plate. The plates are .4m apart with the negatively charged plate having 0v, and the positively charged plate having 500v. Find the location (in cm) where the proton stops and turns around (using the negative plate as x=0).
(sum of) F = ma
(sum of) E = W_nc
F = kQq / r^2
F = qE
E = sigma / epsilon_0
Vf = Vi + at
Vf^2 = Vi^2 +2ax
X = Vit + at^2 / 2
PE = qV
KE = mv / 2
I first attempted to use kinematics, but to find acceleration I would need to find the force either by finding the e-field first and multiplying it with q, or just kQq / r^2. However, I was not given second charge or surface charge density. Is there another way I could go about making the kinematics first or would I have to go to conservation of energy?
I did try conservation of energy but the initial potential energy is where I get stuck. I would try to use PE = qV, but I'm not sure what the potential would be halfway between the capacitor plates. 500 / 2? but I thought the the potential lines were closer together at some points and further at other so I didn't think that just dividing by 2 would be accurate? (image won't attach, hopefully I explained it well enough)
The units of E field are V/m. You are given the capacitor voltage and separation, so you have the E-field in the volume between the plates. Does that help?
There are a few points about the electric field and potential between capacitor plates that you have missed.
1. The field is uniform, meaning it has the same value and direction everywhere between the plates.
2. This means that you cannot use F = kQq / r^2 which is a non-uniform field due to a point charge.
3. The electric potential is given by ##V=Ex## where ##x## is the distance from the negatively charged plate where we are told that the potential is zero.
I suggest that you put these ideas together in an energy conservation argument as you started to do. It's the quickest path to the answer.
Likes berkeman
Thanks for the replies, pretty sure I got it. I was just missing the V = -Ed (had it in an odd location on formula sheet) and the constant E-field. 👍
Likes berkeman
FAQ: Find how far a proton travels between capacitor plates
How do you calculate the distance a proton travels between capacitor plates?
The distance a proton travels between capacitor plates can be calculated using the equation d = (V/m) * (t^2/2), where d is the distance, V is the voltage, m is the mass of the proton, and t is the time.
What is the relationship between voltage and the distance a proton travels between capacitor plates?
The distance a proton travels between capacitor plates is directly proportional to the voltage. This means that as the voltage increases, the distance the proton travels also increases.
How does the mass of the proton affect the distance it travels between capacitor plates?
The mass of the proton does not affect the distance it travels between capacitor plates. The distance is solely determined by the voltage and time.
Can the distance a proton travels between capacitor plates be changed?
Yes, the distance can be changed by adjusting the voltage or the time. Increasing the voltage or time will result in a longer distance traveled, while decreasing them will result in a shorter distance.
Why is it important to know the distance a proton travels between capacitor plates?
Knowing the distance a proton travels between capacitor plates is important for understanding the behavior and properties of electric fields. It can also be useful in designing and optimizing electronic devices that use capacitors.
