Find increase in pulse duration for pulse through fused silica
In summary, the laser pulse passed thru 20 mm of fused silica with an increase of pulse duration of 217.45 fs.
unseenmisfit
Find increase in pulse duration for 10 fs laser pulse going through 20 mm of fused silica
([itex]\phi[/itex][itex]^{(2)}[/itex])=361.626 fs[itex]^{2}[/itex] for 10 mm of fused silica)
I have no idea where to begin with this. Can anyone give me some equations or send me to a page that will help me out?
I had to do some research in for this so don't expect full understanding on my part:
The basis for the pulse stretching is the finite value of d2n/dλ2 in the material. The method is to Fourier-transform the Gaussian electric field pulse and determine its phase spectrum. This gives the usual input-output relationship in terms of a magnitude (attenuation) and phase, both as functions of frequency ω. The transform is in terms of ω-ωc:
Eout = Ein exp[-jø(ω-ωc)]. ωc is the carrier frequency and ω is the Fourier frequency variable.
For a given medium length there is a relation between the incoming pulse width and the outgoing pulse width which includes the coefficient ø2 of the third term in a Taylor series expansion of the spectral phase around the carrier frequency ø(ω-ωc). Thus the units of ø2 are T2 since ø2 is the coefficient of the third-order variable (ωc - ω)2.
You obviously need this Δtin → Δtout formula and I can't give you that without violating forum rules. But you should be able to find it in your textbook or in the Internet as I did.
You're given ø2 for 10 mm of fused silica and the incoming pulse width of 10 fs, so you can now find the output pulse width after passing thru 20 mm of fused silica.
Hint: ø2 = k(ω)L, k(ω) = propagation constant and L = length of the material. Should make it easy to modify the output pulse width from the L=10 mm case to the L=20 mm one.
Okay now I see it in my notes, thank you. Just need someone to explain it.
So [itex]\frac{∂}{∂ω}\frac{1}{v_{g}}[/itex] at [itex]ω_{0}[/itex] is k(ω) and is a constant so [itex]k(ω)*L*\pi/t_{in}=t_{out}[/itex]
[itex]\frac{361.626 fs^{2}}{10 mm}*\frac{20 mm* \pi }{10 fs}=227.216 fs[/itex] with the final answer being [itex]227.216fs-10fs=217.216 fs[/itex]
Is that correct?
My hint was off. Sorry. Should have said ø2 = k2(ω)L, not k(ω)L.
But the rest of my post I think was right. Your computation of Δtout might have been based on that error. Sorry again!
Anyway, the hint that was meant was simply that ø2(20mm) = 2ø2(10mm).
My answer for L=20mm was 200.777 fs if I did the math right. It also reduces to Δtout = Δtin if ø2 = 0 fs2 which is nice!
The theory involves ø2 which you seemingly neglected. Your formula needs to account for the rate of dispersion with respect to λ (= d2n/dλ2) which is the basis for the pulse stretching phenomenon. That's where ø2 comes in.
BTW since the problem asks for the increase in pulse duration I guess you should subtract 10 fs from my answer. Could you post the answer when you get it from the prof? Thanks.
This is what he sent out as the solution... but he wrote 362 instead of 361 so I don't know if he messed up his calculations
[itex]\Delta T_{GDD} \approx \phi^{(2)} \Delta\omega = 362.626 fs^2 \times \frac {\pi}{10 fs} = 227.45 fs[/itex]
[itex]Increase = 217.45 fs[/itex]
Thanks. Does not quite jive with my formula. But when it comes to Gaussian pulses the definition of "pulse width" can vary among folks. In theory the output pulse never vanishes completely. Even if the input pulse has infinitely fast edges, the output gets blurred all the way to infinity. So depending on the cutoff criterion I guess you can get different answers. At least we were off by only about 10%.
My formula was more involved:
Δtout = √{Δtin4 + 16(ln2)2ø22}/Δtin with ø2(20mm) = 2ø2(10mm). That's the total output pulse width so subtract the 10 fs input duration to get elongation.
Related to Find increase in pulse duration for pulse through fused silica
1. What is pulse duration?
Pulse duration refers to the length of time that a pulse of light or energy lasts for. It is typically measured in units of time, such as seconds or milliseconds.
2. How is pulse duration related to fused silica?
Fused silica is a type of glass that is commonly used in optics and laser technology. Its unique properties, such as high transparency and low thermal expansion, make it ideal for controlling the duration of light pulses passing through it.
3. Why is it important to find the increase in pulse duration for pulse through fused silica?
Understanding the increase in pulse duration for pulses passing through fused silica is crucial for optimizing the performance of laser systems. It can also help to predict potential damage to the material and ensure the safety of the equipment and operators.
4. How can the increase in pulse duration for pulse through fused silica be measured?
The increase in pulse duration can be measured using various techniques, such as interferometry or autocorrelation. These methods involve splitting the pulse into two beams and then recombining them to observe any changes in their duration.
5. What factors can affect the increase in pulse duration for pulse through fused silica?
The increase in pulse duration can be influenced by several factors, including the material properties of fused silica, the intensity and duration of the pulse, and the angle of incidence. Other factors, such as temperature and impurities in the material, can also play a role.
12K
