MHB Find Integer $k$ to Satisfy Sum of Inverse Progression > 2000
An integer \( k \) must be found such that the sum \( \frac{1}{k} + \frac{1}{k+1} + \frac{1}{k+2} + \cdots + \frac{1}{k^2} \) exceeds 2000. One participant confirmed their solution is correct and expressed appreciation for the challenge. The thread encourages further submissions and discussion on the problem. A solution from another source is mentioned but not detailed. Engaging with this challenge can enhance problem-solving skills in inverse progression.
anemone
MHB
POTW Director
Find an integer $k$ for which $\dfrac{1}{k}+\dfrac{1}{k+1}+\dfrac{1}{k+2}+\cdots+\dfrac{1}{k^2}>2000$.
Mathematics news on Phys.org
I try:
$\displaystyle\dfrac{1}{k}+\dfrac{1}{k+1}+\dfrac{1}{k+2}+\cdots+\dfrac{1}{k^2}=\sum_{1}^{k^2}\dfrac{1}{n}-\sum_{1}^{k-1}\dfrac{1}{n}$
The partial sums of the harmonic series have logarithmic growth i.e. $\displaystyle\sum_{1}^{k}\dfrac{1}{n}\sim \ln k$
therefore
$\displaystyle\sum_{1}^{k^2}\dfrac{1}{n}-\sum_{1}^{k}\dfrac{1}{n}\sim \ln k^2-\ln (k-1)=\ln\dfrac{k^2}{k-1}$.
$\ln\dfrac{k^2}{k-1}>2000\ \Rightarrow\ \dfrac{k^2}{k-1}>e^{2000}\ \Rightarrow k>\dfrac{e^{2000}+\sqrt{e^{4000}-4e^{2000}}}{2}$.
$\dfrac{e^{2000}+\sqrt{e^{4000}-4e^{2000}}}{2}\sim 3.88\cdot 10^{868}$.
$4\cdot 10^{868}$ should be enough...
laura123 said:
I try:
therefore
Hi Laura123,
Sorry for the late reply. I can explain...Actually I hoped there would be more submissions for this challenge, that was why I waited a bit longer...:o
You have done a great job there and your answer is correct, well done! And thanks for participating in this particular challenge.
I want to share with you and other members the solution that I have found online:
Solution of other:
Any integer $k>e^{2000}$ suffices.
For $\displaystyle \sum_{n=k}^{k^2} \dfrac{1}{n}=\int_{k}^{k^2+1} \dfrac{1}{\left\lfloor{x}\right\rfloor}\,dx>\int_{k}^{k^2} \dfrac{1}{x}\,dx=\ln k$
and $\ln k>2000$ when $k>e^{2000}$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
