MHB Find Integral: $\int_{a}^{\infty}e^{-st}t^{n}dt$
  • Thread starter Thread starter evinda
    Integral
To find the integral $\int_{a}^{\infty} e^{-st} t^{n} dt$, multiple differentiation using integration by parts is suggested, as it eliminates the $t^n$ term. The incomplete gamma function is also relevant, particularly since $n$ is a positive integer, which ensures convergence. The complete integral can be expressed as $\int_{0}^{\infty} e^{-st} t^{n} dt = \frac{n!}{s^{n+1}}$, derived through integration by parts or the gamma function. For the case of the integral from $a$ to $\infty$, the result involves the incomplete gamma function, and the calculations can be complex. The discussion emphasizes the importance of verifying results with specific values for $n$, $s$, and $a$.
  • #31
evinda said:
Oh sorry!I accidentally wrote at one equation twice the $s$..
Now,I get $$I_{n}=e^{-sa}\Sigma_{k=1}^{n} \frac{a^{n+1-k}}{s^{k}}\frac{n!}{(n-k+1)!}+\frac{n!I_{0}}{s^{n}}$$ .
What have I done wrong now?? :confused:
In retrospect I believe that is correct.
I had summed with different indices and I made a mistake when converting those.
- - - Updated - - -
And also...why do we know that with $a=0$ we should get $\mathcal L\{t^n\} = \frac{n!}{s^{n+1}}$ ?
Applying the definition of the Laplace transform we have:
$$\mathcal L\{t^n\} = \int_0^\infty e^{-st}t^n dt$$
This is your integral with $a=0$.
Additionally, in post http://mathhelpboards.com/differential-equations-17/find-integral-8382-2.html#post38771 and post http://mathhelpboards.com/differential-equations-17/find-integral-8382-2.html#post38777, I showed in different ways that it is equal to $$\frac{n!}{s^{n+1}}$$.
  • #32
Great! :o
oh yes!Right!And to explain why it is right,can I just say that it is verified for $a=0$ ?
  • #33
evinda said:
Great! :o
To be honest, that is only very little verification, since it doesn't touch the sum-part of the expression.
For a proper verification, I think you should also verify it for say $a=1$ and $n=1$ and also for $a=2$ and $n=3$.
Easy enough to do with W|A.
  • #34
I checked it for the values $a=1$ and $n=1$ and $a=2$ and $n=3$,and the results were the same with the Laplace transform! :) So,do I have to write these two examples,for verification?
  • #35
Good! ;)
No need. It suffices that you are sure that your formula is correct.
You should write down the steps how you got to the formula though.
  • #36
I like Serena said:
Good! ;)
I have already done...Thank you very much for your help! (Tongueout)
  • #37
Use induction on $n$ to show it is correct.
  • #38
So,for $a=0$ ,we know that it is true.
We suppose that it is true for $a$.
Then I write the equation for $a+1$ ,but how can I continue?? :confused:
  • #39
Using induction on $n$ implies that we have to prove that
1- For $$n=0$$ we have
$$I_{0}=\frac{0!I_{0}}{s^{0}}=I_0$$ .
2- Assume that
$$I_{n}=e^{-sa}\sum_{k=1}^{n} \frac{a^{n+1-k}}{s^{k}}\frac{n!}{(n-k+1)!}+\frac{n!I_{0}}{s^{n}} $$
is true and prove that $$I_{n+1}=e^{-sa}\sum_{k=1}^{n+1} \frac{a^{n+2-k}}{s^{k}}\frac{(n+1)!}{(n-k+2)!}+\frac{(n+1)!I_{0}}{s^{n+1}}$$
It might be difficult but it is a really good exercise.
  • #40
2- Assume that
Ok,thank you! :o
  • · Replies 17 ·
