Find Isobaric Expansion & Pressure-Volume Coefficient for Solid
The discussion centers on finding the isobaric expansion and pressure-volume coefficients for a solid, with participants analyzing the derivatives of volume with respect to temperature and pressure. The initial calculations presented involve deriving the coefficients, but confusion arises regarding the relationship between the variables and the correctness of the textbook solution. It is suggested that the textbook may have provided a polynomial in temperature rather than the expected form of the derivatives. Participants clarify that the answers should be expressed as partial derivatives, indicating a potential mix-up in the original question and its corresponding answer. The conversation concludes with a participant expressing gratitude for the clarification received.
member 731016
The problem I am trying to solve is,
Find the isobaric expansion coefficient ##\frac{dV}{dT}## and the isothermal pressure-volume coefficient ##\frac{dV}{dP}## of a solid that has equation of state ##V+bpT–cT^2=0##
Equation of state of solid: ##V+bpT–cT^2=0##
The answer to this problem is
However, I am confused how this relates to the question.
My working is,
##V = cT^2 - bpT##
##\frac{dV}{dT} = 2cT - bp## (I take the partial derivative of volume with respect to temperature to get the isobaric expansion coefficient)
##\frac{dV}{dP} = 0## (I take the partial derivative of volume with respect to pressure to get the isothermal pressure-volume coefficient)
If someone please knows whether I am correct or not then that would be greatly appreciated!
Many thanks!
I suspect that p and P are supposed to be the same.
Likes member 731016
Thank you for your reply @haruspex!
That gives ##\frac{dV}{dP} = -bT##. Do you please know whether the textbook solution is wrong? It appears they just give a polynomial in temperature.
Many thanks!
Many thanks!
It is obviously not an answer to the question. It merely restates the given equation. The answers must take the form ##\frac{dV}{dT}=## etc. Or better, ##\frac{\partial V}{\partial T}=## etc.
Perhaps the original question was the reverse: it provided the partial derivatives and asked for the state equation. Someone changed the question but forgot to change the answer.
Likes member 731016
Thank you for your help @haruspex ! I understand now :)
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
