Find its velocity as a function of time?
In summary, the boat weighing 64,000 lb has a propeller with a constant thrust of 50,000 lb. The water exerts a resistive force proportional to the boat's speed, with a constant of proportionality of 2000 lb-s/ft. Starting from rest, the boat's velocity as a function of time can be found using the equation v=32(e^(-t)-1). The terminal velocity is 25 ft/s. However, to accurately solve this problem, the net horizontal force equation should be used, taking into account the resistive force from the water.
Math10
301
A boat weighs 64,000 lb. Its propeller produces a constant thrust of 50,000 lb and the water exerts a resistive force with magnitude proportional to the speed, with k=2000 lb-s/ft. Assuming that the boat starts from rest, find its velocity as a function of time, and find its terminal velocity.
F=mg
F=ma
F=mg
F=ma
m=64000/32=2000
a=2000v/2000=v
dv/dt=-g-v
dv/dt=-32-v
-dv/(32+v)=dt
-ln abs(32+v)=t+C
ln abs(32+v)=-t+C
32+v=Ce^-t
v=Ce^(-t)-32
v(0)=0
C=32
v=32(e^(-t)-1)
The answer in the book is v=25(1-e^(-t)); 25 ft/s. So where did I got wrong? Please correct me.
In this problem, the force of gravity is balanced by the upward force of water on the boat. So gravity has nothing to do with the motion, which is only in the horizontal direction. I don't see that any of your work incorporates the statement that "the water exerts a resistive force with magnitude that is proportional to speed [of the boat]". Start your work with an equation that gives the net force on the boat in the horizontal direction.
I can make no sense of your calculation. How is g involved? Why do you divide by 32? Is a acceleration and v velocity? If so, how can a=v?
Some tips:
- work entirely symbolically, not plugging in numbers until the final step
- define your variables
- symbolic variables have dimension, but not units; constants have units. Thus, m=64000 is wrong, m=64000 lb can be right. a=v is wrong, a= v / (1 hour) can be right.
Related to Find its velocity as a function of time?
1. How do you find the velocity as a function of time?
To find the velocity as a function of time, you need to know the equation for velocity, which is v = d/t, where v is velocity, d is distance, and t is time. You also need to have data on the distance and time for the object in question.
2. What is the difference between velocity and speed?
Velocity and speed are often used interchangeably, but they have different meanings in physics. Velocity is a vector quantity that includes both the speed and direction of an object's motion, while speed is a scalar quantity that only measures how fast an object is moving without considering direction.
3. Can you find the velocity as a function of time for an accelerating object?
Yes, it is possible to find the velocity as a function of time for an accelerating object. In this case, the equation for velocity becomes v = v0 + at, where v0 is the initial velocity, a is the acceleration, and t is the time.
4. How does the velocity change with time for an object moving at a constant velocity?
If an object is moving at a constant velocity, its velocity will remain the same over time. This means that the velocity as a function of time will be a straight horizontal line on a graph, with the slope representing the constant velocity.
5. What other factors can affect an object's velocity as a function of time?
Other factors that can affect an object's velocity as a function of time include changes in acceleration, changes in direction, and external forces acting on the object such as friction or air resistance. These factors can cause the velocity to increase, decrease, or change direction over time.
