Find Length of Line D in ABC Triangle
Hence, in the given triangle ABC, the length of the line segment D is \frac{\sqrt{79}}{5}.In summary, to find the length of a line drawn inside a scalene triangle, we first use the given information and the Law of Cosines to determine the value of a specific angle. Then, we use this angle and the Law of Cosines again to calculate the length of the line segment.
MarkFL
MHB
13,288
Here is the question:
How will you find the length of a line drawn inside a scalene triangle?
ABC is a scalene triangle, in which AB = 3, AC = 4 and BC = 6
D is the line joining A with BC.such that BD : DC : :2 :3
I have posted a link there to this topic so the OP can see my work.
Mathematics news on Phys.org
Re: Sepia's question ay Yahoo! Answers regarding finding the length of a line segment within a trian
Hello Sepia,
Let's first draw a diagram:
We see that:
\(\displaystyle u+v=6\)
and we are given:
\(\displaystyle \frac{u}{v}=\frac{2}{3}\implies u=\frac{2}{3}v\)
Substituting this into the first equation, we then find:
\(\displaystyle \frac{2}{3}v+v=6\)
\(\displaystyle \frac{5}{3}v=6\)
\(\displaystyle v=\frac{18}{5}\)
Now, let's use the Law of Cosines to determine the cosine of the angle $\theta$:
\(\displaystyle 3^2=4^2+6^2-2\cdot4\cdot6\cos(\theta)\)
\(\displaystyle \cos(\theta)=\frac{4^2+6^2-3^2}{2\cdot4\cdot6}=\frac{43}{48}\)
Next, using the Law of Cosines again, we may state:
\(\displaystyle x=\sqrt{4^2+v^2-2\cdot4\cdot v\cos(\theta)}\)
\(\displaystyle x=\sqrt{4^2+\left(\frac{18}{5} \right)^2-2\cdot4\cdot\left(\frac{18}{5} \right)\left(\frac{43}{48} \right)}=\frac{\sqrt{79}}{5}\)
FAQ: Find Length of Line D in ABC Triangle
How do you find the length of line D in an ABC triangle?
To find the length of line D in an ABC triangle, you can use the Pythagorean theorem. This theorem states that the square of the length of the hypotenuse (line D) is equal to the sum of the squares of the other two sides (lines A and B). Simply plug in the values of lines A and B to find the length of line D.
Can you use any other methods to find the length of line D?
Yes, you can also use trigonometric functions such as sine, cosine, and tangent to find the length of line D. However, this method may be more complex and may require knowledge of the angles in the triangle.
What if the triangle is not a right triangle?
If the triangle is not a right triangle, you can use the Law of Cosines to find the length of line D. This law states that the square of the length of the side opposite an angle is equal to the sum of the squares of the other two sides minus twice the product of the two sides and the cosine of the angle.
Can you find the length of line D if only the angles of the triangle are given?
No, you will need at least one side length in addition to the angles to find the length of line D. Otherwise, the triangle will have an infinite number of possible lengths for line D.
How accurate will the calculated length of line D be?
The accuracy of the calculated length of line D will depend on the accuracy of the measurements of lines A and B. If these measurements are precise, then the calculated length of line D will also be precise. However, if there are any errors in the measurements, it may affect the accuracy of the calculated length of line D.
