Find magnetic force on semicircle using line integral
In summary, the problem involves a thin wire in the shape of a semicircle with a constant current flowing through it and a uniform magnetic field acting on it. To find the total force on the wire due to the magnetic field, we can use the formula F = iBπR, where i is the current, B is the magnetic field, and R is the radius of the semicircle. However, this formula only works for a straight conductor, so we need to resolve the force into two components and integrate from 0 to π to find the net force. This may explain why the previous answer was incorrect.
auk411
57
Here is the question:
A very thin wire which follows a semicircular curve C of radius R,lies in the upper half of the x-y plane with its center atthe origin. There is a constant current I flowing counter clockwise, starting upward from the end of the wire on the positive x-axis and ending downward at the end on thenegative x axis. The wire is in a uniform magneticfield, which has magnitude B0 and direction parallel to the z-axis in the positive z direction. Determine a symbolic answer in unit-vector notation for the total force on the wire due to the magneticfield. Ignore the forces on the leads that carry the current into the wire at the right end and out of the wire at the leftend.
(Solution check: The numerical value with I =2.00 A, B0 = 3.00 T, and R =4.00 m is 48.0 N in j direction.)
I am not getting the right answer.
First, we know that dF[itex]^{\rightarrow}[/itex] = i dL[itex]^{\rightarrow}[/itex] x B[itex]^{\rightarrow}[/itex].
So [itex]\int[/itex]dF[itex]^{\rightarrow}[/itex] = i [itex]\int[/itex]dL[itex]^{\rightarrow}[/itex] x B[itex]^{\rightarrow}[/itex].
Then, since B is always perpendicular to L, we have a sin of 90 degrees. This implies that (along with B being constant)
F = iB[itex]\int dL[/itex].
The arclength of a circle is 2[itex]\pi[/itex]R. A semicircle's arclength is [itex]\pi[/itex]R.
Therefore F = iB[itex]\pi[/itex]R.
This doesn't get you to the right answer. What am I doing wrong? Why isn't my answer right? And is there some physical quantity that my answer does correspond to?
If you consider a small segment dL of the wire, the force acting on it will be
dF = i*B*dL. The force is radial.
Due to symmetry component of this force, dF*cos(theta), gets canceled out.
dF*sin(theta) adds up to give net force on the wire.
Write dL as R*d(theta)
Now find the integration from zero to pi to get the net force.
It would be most appreciated if you answer the questions that are asked. You answered how to solve it. I didn't ask that. I asked why mine was wrong. There are subtle differences. For example, I'm still confused by your answer because I'm not sure how (or if one can) integrate the following, given some angle that B makes with some tiny L.
So there are reasons I asked what I did.
Your method is correct if the the conductor is straight. In the semicircular conductor, the force on the each element of the conductor experiences a force in the radial direction. To find the net force, resolve dF into two components. Net dF*cos(theta) is zero. Net dF*sin(theta) is -i*B*R*cos(theta).Substitute the limits from 0 to pi to find the net force.
Your approach using the line integral is correct, but there are a few key details that need to be considered.
Firstly, the direction of the current needs to be taken into account. In this case, the current is flowing counter-clockwise, so the direction of the force will be in the opposite direction. This means that the unit vector notation for the force should be -j instead of j.
Secondly, the integral needs to be taken over the entire semicircle, not just a portion of it. This can be achieved by using the limits of integration from 0 to \pi.
Finally, the force is a vector quantity, so it needs to be written in terms of its components. The x-component of the force will be zero since the magnetic field is parallel to the z-axis and the current is flowing in the x-direction. The y-component of the force will be given by F_y = iB\piR = (2.00 A)(3.00 T)(4.00 m) = 24.0 N.
Therefore, the total force on the wire due to the magnetic field is given by F = -24.0 j N. This corresponds to the physical quantity of the force acting downwards on the wire due to the interaction between the current and the magnetic field.
Related to Find magnetic force on semicircle using line integral
1. What is a line integral?
A line integral is a mathematical tool used to calculate the total value of a function along a specific curve or path. It can be thought of as a generalization of the concept of a definite integral, but instead of integrating over a fixed interval, it integrates over a variable curve.
2. How is a line integral used to find the magnetic force on a semicircle?
To find the magnetic force on a semicircle, a line integral is used to calculate the total magnetic field along the curve of the semicircle. This involves integrating the product of the magnetic field vector and the differential length element of the curve.
3. What factors affect the magnetic force on a semicircle?
The magnetic force on a semicircle is affected by several factors, including the strength and direction of the magnetic field, the radius of the semicircle, and the current flowing through the semicircle.
4. Can the line integral method be used to find the magnetic force on any curve?
Yes, the line integral method can be used to find the magnetic force on any curve, as long as the necessary parameters and equations are known. However, the complexity of the curve may affect the difficulty of the calculation.
5. How does the magnetic force on a semicircle compare to that on a full circle?
The magnetic force on a semicircle is half of the force on a full circle, since a semicircle only covers half of the total circumference of a circle. This can be mathematically represented by the fact that the integration limits for a semicircle are divided by 2 compared to those of a full circle.
