Find magnitude of car's acceleration
In summary: Also, why does the length of the car matter? The question asks for magnitude of acceleration.In summary, the problem involves calculating the acceleration of an Alfa Romero car that was seen passing through a narrow alleyway in 0.5 seconds. The length of the car, 4m, and the fact that it started from rest 2 seconds before it was first seen, are also given. Using the equation Δx = Voxt + (1/2)axt^2, the magnitude of the acceleration was calculated to be approximately 4.6 m/s^2. However, there may be some discrepancies in the problem statement that could affect the answer.
Rijad Hadzic
321
While strolling downtown on a Saturday afternoon you stumble across an old car show. As you are walking along an alley toward a main street, you glimpse a particularly stylish Alpha Romero pass by. Tall buildings on either side of the alley obscure your view, so you see the car only as it passes between the buildings. Thinking back to your physics class, you realize that you can calculate the cars acceleration. You estimate the width of the alley way between the two buildings to be 4 m. The car was in view for .5s. You also heard the engine rev when the car started from a red light, so you know the alpha romero started from rest 2s before you first saw it. Find the magnitude of its acceleration
[itex] V_{ox} + a_xt = V_x [/itex]
[itex] \Delta x = V_xt - (1/2) a_xt^2 [/itex]
So since the car starts from 0 velocity, its final velocity =
[itex] V_x = a_x(t_2) [/itex]
where [itex] t_2 = 2 s[/itex]
its initial velocity [itex] V_{ox} = 2\Delta x + a_xt_1^2 / (2t_1) [/itex] where [itex] t_1 = .5s [/itex]
is = to the final velocity first equation, so the two are =
[itex] 2\Delta x + a_xt_1^2 / (2t_1) = a_x(t_2) [/itex]
now solving
[itex] a_x (2t_1)(t_2) = 2\Delta x + a_x t_1^2 [/itex]
[itex] a_x(2t_1)(t_2) - a_xt_1^2 = 2\Delta x [/itex]
[itex] a_x [ (2t_1)(t_2) - (t_1)^2 ] = 2\Delta x [/itex]
[itex] a_x = (2\Delta x ) / (2t_1)(t_2)-(t_1^2) [/itex]
[itex] = a_x = 8 m / (1s)(2s) - (.5s)^2 = 8m / (1.75 s)^2 = 4.6 m/s^2 [/itex]but my book is telling me my answer is aboout 4 seconds.
My answer is closer to 5 seconds.
Does anyone know what I did wrong? Maybe the way I set up my eq's?
Check ##\Delta x = V_xt - (1/2) a_xt^2## : do you really think an accelerating car would go backwards after ##2v\over a## seconds ?
I think I understand now. To answer your question, no lol.
Using [itex] \Delta x = V_{ox}t + (1/2)a_xt^2 [/itex] would make sense because the velocity and acceleration would be consistent, right?
and my [itex] V_{ox} [/itex] would be = to my first equations [itex] V_x [/itex] anyways so I can set them equal, right? Sin [itex] V_{ox} [/itex] is just another way of writing [itex] V_x [/itex]
Anyways did the problem again and got 3.6, and they say the answer is ABOUT 4 which is pretty vague but I think I did it correctly now using
where Vox = Vx in the first equation
I get your answer if I ignore the length of the car. Never heard of Alfa Romero, but an Alfa Romeo Giulia is over 4m long. If it was in (at least partial) view for 0.5s then it traveled about 8m in that time, making the acceleration more like 7m/s2.
I agree. Haru points out a weakness in the problem statement. Not clear if a single point on the car is in view for 0.5 s (which I think was intended -- so car travels 4m in 0.5 s) or any part of the car (as Haru explains).
Related to Find magnitude of car's acceleration
1. What is the formula for finding the magnitude of a car's acceleration?
The formula for finding the magnitude of a car's acceleration is a = (vf - vi)/t, where a is acceleration, vf is final velocity, vi is initial velocity, and t is time.
2. How is acceleration different from velocity?
Acceleration measures the rate of change of velocity over time, while velocity is the rate of change of position over time. In other words, acceleration measures how fast the velocity is changing, while velocity measures how fast an object is moving in a particular direction.
3. What units are used to measure acceleration?
Acceleration is typically measured in meters per second squared (m/s²) in the SI system, or feet per second squared (ft/s²) in the imperial system.
4. How does the magnitude of a car's acceleration affect its motion?
The magnitude of a car's acceleration determines how quickly the car's velocity changes. A larger magnitude of acceleration will result in a faster change in velocity, leading to a greater change in speed or direction of the car's motion.
5. What factors can affect the magnitude of a car's acceleration?
The magnitude of a car's acceleration can be affected by factors such as the car's engine power, weight, and friction from the road. It can also be affected by external forces such as wind or gravity.
